Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Weak connection or no connection to the switch.
There is an issue when trying to connect your controller.
Joycons not fully attached when docked.
Make sure the Joycons are clicked in place or fully off the switch when docked.
Flight Mode (airplane mode)
Check to see if the switch is in flight mode as it disables some wireless functionality.
Very Low Battery/No Battery
The controller may have issues connecting if the battery is near empty or empty. Charge it to check if this is the issue.
Not synced up
Your controller may not be synced to your switch, try connecting it again.
Not turned on
Your controller may not be on, try turning it on again.
Button Input is Non-Responsive
Button input is not registering.
System may be out of date
  1. Ensure controller connected to device
  2. If the firmware is up to date, and the controller is connected, reset the controller by pressing the SYNC button
  3. Press any other button to wake up the controller
How to test Inputs:
  1. Access settings in the Nintendo Switch Console
  2. Select “CONTROLLERS AND SENSORS”
  3. Select “TEST INPUT DEVICES”
  4. Select “TEST CONTROLLER BUTTONS”
Press the button or control stick on the controller you wish to test.
  • Test the joysticks as well as the controller buttons
  • One a button has been pressed, they will appear on screen, alerting you that the button is functional
Note: The test does not check for these buttons:
  • HOME Button
  • Capture Button
  • POWER Button
  • Volume Buttons
  • SYNC Button
-If all buttons appear on screen, your controller has passed.
-Next, Test the Pro Controller buttons using a compatible game or application, and ensure that all buttons are responsive.
  • If you have passed the button test but still have problems when running certain apps or games, you should:
    • Check the game manual to ensure compatibility with the Pro Controller
    • Move the controller closer to the Nintendo Switch System/Clear any objects between the controller and the system
    • Remove other wireless devices from the area which may be interfering with the remote.
    • If possible test the Pro Controller on a different console to determine if the error is with the Switch itself
  • If the button test fails, either reference our Button replacement guide or take the controller to be repaired.
Joystick not responding
When the joystick is moved, the device doesn’t respond on the screen.
Manufacturer Variation in Left Joystick
If the left joystick isn’t responding without clear reason, a manufacturing issue could be the cause however there’s a simple fix that requires just 3 steps:
  • Step one: Turn off the device, and obtain a clean toothbrush and isopropyl alcohol
  • Step two: Wet the toothbrush with the alcohol, making sure not to completely soak it because the liquid could damage the device even more
  • Step three: Carefully brush under the joystick with the toothbrush to remove any debris that could be there
Lastly, turn on the device and find out if the problem is solved!
The Controller Won’t Power On
The controller is not turning on, cannot be charged, or hold its charge.
Dead Batteries
Your battery level may be very low. Connect your controller to the Switch console via the provided USB-C cable for about 6 hours or until the orange light at the top of the controller turns off.
Battery is Defective
Your controller’s battery may be defective. If the battery is not holding power for approximately 40 hours of play time, you may have to replace the battery pack.
Part: Pro Controller Battery Replacement
Tools Required: Phillips #00 Screwdriver
Charging cable is Defective
The charging cable may be defective and therefore will not properly charge your controller. You may have to get a replacement USB-C cable for your controller.
Part: USB-C cable
Controller not Synced with the Switch console
After pressing the power button, you may notice that the LED light at the bottom of your controller flashes from left to right and eventually shuts off. This means that the controller is not properly synced to the Switch console. To sync your controller, use either of the following methods:
Sync via USB Type-C:
Connect the USB Type-A end into the dock and the USB Type-C end into Pro controller. Press the power button on the controller. The console should now respond to controller input. If not, refer to the latter method.
Part: USB-C cable
Sync via “Sync” Button:
  • Step 1: Select the “Change Grip/Order” setting from the Controllers menu on the Home screen with the included JoyCon controllers
  • Step 2: Press & hold the sync button at the top of the Pro controller until the controller lights begin to flash
Joystick drifting
Your joystick moves on its own and your inputs becomes inaccurate, or the controller is not responding to commands correctly.
The joysticks are not calibrated
If the joysticks haven’t been calibrated for a long time, minor drifting could happen.
To solve this, go to settings --- controllers and sensors -- stick calibration tool, to re calibrate the Joystick.
System is not up to date
If the system is not up to date, it might not process inputs from the joysticks correctly.
To solve this, go to settings --- system update, to update to the latest system.
Controller is not synced correctly
The controller might not have sync correctly to the Nintendo Switch console.
To solve this, go to controllers --- pair new controllers, disconnect all controllers and reconnect them.
Joystick is dusty
The base of the joystick might be dusty, which could cause joysticks to drift.
To solve this, clean the base of the joystick thoroughly.
Tools required: paper towels and rubbing alcohol.
The graphite inside the controller is not conducting well
The controller in conducted with graphite internally and it may have worn off after significant play time, causing conducting issues and joystick drifting.
To solve this, you may have to replace the joystick module.
Tools and parts required: replacement joystick package
Author
with
Daniel Tagalog
2,219 Reputation
3 Guides authored
Cal Poly, Team S11-G2, Regan Fall 2019 Member of Cal Poly, Team S11-G2, Regan Fall 2019
CPSU-REGAN-F19S11G2
5 Members
72 Guides authored
28 Comments
Where can I get my nintendo switch pro controller repaired? Everything works except the wireless part. It won't sync no matter what I do. Only works plugged into the switch. I've done every troubleshooting guide I could find to no avail.
rainbowlindy - Reply Share
I have the exact issue! did you get it fixed?
Keaton Hulme-Jones - Reply Share
Same issue. Works on cable, but reporting low battery. Does not work when disconnecting from cable. I tried replacing battery.
Marcus Assarlind - Reply Share
Same for mine
God5Gamer YT - Reply Share
Can anyone help my pro controller has its player1 light on yet not sync to my switch and it won't respond what ever
Anthony Jordan - Reply Share
Past 24 Hours: 17
Past 7 Days: 121
Past 30 Days: 644
All Time: 159,914
