Up to 20% off select tools
Nintendo Switch Pro Controller Battery Replacement
Views: 107K
View statistics:
Past 24 Hours:
58
Past 7 Days:
393
Past 30 Days:
2,035
All Time:
107,384
Comments: 20
6 comments on steps, 14 guide comments.
Go to guide comments
Completed: 46
46 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Welcome! Does the battery in your controller not last as long as it used to or not at all? You must be looking to replace the battery in your Nintendo Switch Pro Controller, well you have come to the right place! Below you will find instructions for replacing the battery in your controller, read them carefully and follow the steps in order from one to six.
The Switch Pro Controller uses JIS screws. Be sure not to use a Phillips screwdriver to remove them, as it will potentially strip the screws.
NOTE: an improperly sync Switch Pro controller will not charge properly. To determine if your battery is faulty and needs replacing, you can first re-sync your controller and, while plugged in, check within the Switch controllers menu if it is charging properly.
CAUTION: The handling of any swollen batteries should be done with the utmost care. For information on how to identify, what to do with, how to handle, and how to dispose of swollen batteries follow the link below.
What to do with a swollen battery
    1. Nintendo Switch Pro Controller Battery Replacement, Remove the screws: step 1, image 1 of 1
      • Flip the controller over so the model stickers face the ceiling.
      • Use a JIS #00 screwdriver to remove the two black 8.4 mm screws that secure the handles, located at the ends of the handles.
      Ask FixBot
    2. Nintendo Switch Pro Controller Battery Replacement, Remove the handle covers: step 2, image 1 of 3 Nintendo Switch Pro Controller Battery Replacement, Remove the handle covers: step 2, image 2 of 3 Nintendo Switch Pro Controller Battery Replacement, Remove the handle covers: step 2, image 3 of 3
      • Carefully remove the handle covers by pulling them away from the main body.
      Ask FixBot
    3. Nintendo Switch Pro Controller Battery Replacement, Remove the screws: step 3, image 1 of 1
      • Use a JIS #00 screwdriver to remove the four silver 6.8 mm screws that secure the clear back plastic cover.
      Ask FixBot
    4. Nintendo Switch Pro Controller Battery Replacement, Unclip the plastic cover: step 4, image 1 of 3 Nintendo Switch Pro Controller Battery Replacement, Unclip the plastic cover: step 4, image 2 of 3 Nintendo Switch Pro Controller Battery Replacement, Unclip the plastic cover: step 4, image 3 of 3
      • Carefully pry away the clear plastic cover using your fingernail.
      Ask FixBot
    5. Nintendo Switch Pro Controller Battery Replacement, Remove the clear plastic cover: step 5, image 1 of 1
      • Remove the clear plastic cover.
      Ask FixBot
    6. Nintendo Switch Pro Controller Battery Replacement, Remove the battery: step 6, image 1 of 3 Nintendo Switch Pro Controller Battery Replacement, Remove the battery: step 6, image 2 of 3 Nintendo Switch Pro Controller Battery Replacement, Remove the battery: step 6, image 3 of 3
      • Remove the lithium-ion battery by using a fingernail or plastic opening tool to pry it up on the left side.
      • Only a small amount of force is needed.
      Ask FixBot
For optimal performance, calibrate your newly installed battery after completing this guide.
46 other people completed this guide.
Author
with
Daniel Tagalog
2,219 Reputation
3 Guides authored
Cal Poly, Team S11-G2, Regan Fall 2019 Member of Cal Poly, Team S11-G2, Regan Fall 2019
CPSU-REGAN-F19S11G2
5 Members
72 Guides authored
14 Guide Comments
now what after taking the battery out
Seani M - Reply Share
Install the replacement battery and follow the steps in reverse order…
frzno72 - Reply Share
easy peasy only have to recycle battery
Dan Carroll - Reply Share
Where can I buy genuine ctr-003 batteries in germany/europe?
smol_tsukiko - Reply Share
You can buy them directly in the iFixit Europe or in your case in the Germany store.
Henrynaja - Reply Share
Past 24 Hours: 58
Past 7 Days: 393
Past 30 Days: 2,035
All Time: 107,384
