Up to 20% off select tools
Nintendo Switch Pro Controller Buttons / D-Pad Replacement
Views: 46K
View statistics:
Past 24 Hours:
15
Past 7 Days:
153
Past 30 Days:
671
All Time:
46,085
Comments: 24
21 comments on steps, 3 guide comments.
Go to guide comments
Completed: 26
26 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The Nintendo Switch Pro controller’s buttons and D-Pad are the main inputs of the controller. The buttons may need to be replaced if they are unresponsive, please check out our troubleshooting guide for more information.
During disassembly be careful of sharp edges, there are a few exposed pieces of plastic that could cut you.
    1. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the screws: step 1, image 1 of 1
      • Flip the controller over so the model stickers face the ceiling.
      • Use a JIS #00 screwdriver to remove the two black 8.4 mm screws that secure the handles, located at the ends of the handles.
      Ask FixBot
    2. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the handle covers: step 2, image 1 of 3 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the handle covers: step 2, image 2 of 3 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the handle covers: step 2, image 3 of 3
      • Carefully remove the handle covers by pulling them away from the main body.
      Ask FixBot
    3. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the screws: step 3, image 1 of 1
      • Use a JIS #00 screwdriver to remove the four silver 6.8 mm screws that secure the clear back plastic cover.
      Ask FixBot
    4. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Unclip the plastic cover: step 4, image 1 of 3 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Unclip the plastic cover: step 4, image 2 of 3 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Unclip the plastic cover: step 4, image 3 of 3
      • Carefully pry away the clear plastic cover using your fingernail.
      Ask FixBot
    5. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the clear plastic cover: step 5, image 1 of 1
      • Remove the clear plastic cover.
      Ask FixBot
    6. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the battery: step 6, image 1 of 3 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the battery: step 6, image 2 of 3 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the battery: step 6, image 3 of 3
      • Remove the lithium-ion battery by using a fingernail or plastic opening tool to pry it up on the left side.
      • Only a small amount of force is needed.
      Ask FixBot
    1. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the screws: step 7, image 1 of 3 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the screws: step 7, image 2 of 3 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the screws: step 7, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the five 5 mm screws from the back of the controller.
      • The two case screws above the handgrips and the single case screw below the battery bay have a shallow seat. These three screws can be easily removed.
      • The two case screws adjacent to the ZR and ZL shoulder buttons have a deep seat. Use an extension or a narrow PH1 Phillips screwdriver with a longer shaft to reach these screws.
      Ask FixBot
    2. Nintendo Switch Pro Controller Buttons / D-Pad Replacement: step 8, image 1 of 3 Nintendo Switch Pro Controller Buttons / D-Pad Replacement: step 8, image 2 of 3 Nintendo Switch Pro Controller Buttons / D-Pad Replacement: step 8, image 3 of 3
      • There's an adhesive pad located in the center of each handle. It will require a bit of force to pry away the front cover, but be mindful of the attached ribbon cable.
      • Delicately take off the plastic cover from the controller.
      • Don't completely remove the front cover just yet, as it's still attached to the motherboard via a white ribbon cable.
      Ask FixBot
    3. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Open the flap: step 9, image 1 of 2 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Open the flap: step 9, image 2 of 2
      • Use the tip of an opening pick to open the black flap of the ZIF connector by pushing it upwards.
      Ask FixBot
    4. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Disconnect the interconnect cable: step 10, image 1 of 2 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Disconnect the interconnect cable: step 10, image 2 of 2
      Tool used on this step:
      Buy
      • Use your fingers or a pair of blunt nose tweezers to disconnect the interconnect cable from its connector.
      Ask FixBot
    5. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the front case: step 11, image 1 of 1
      • Remove the front case.
      Ask FixBot
    1. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the screws: step 12, image 1 of 1
      • Remove the two 6.8 mm-long screws on the top circuit board using a Phillips screwdriver.
      Ask FixBot
    2. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Open the ZIF connector: step 13, image 1 of 2 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Open the ZIF connector: step 13, image 2 of 2
      • Use a spudger to flip up the locking tab on the ZIF connector.
      Ask FixBot
    3. Nintendo Switch Pro Controller Buttons / D-Pad Replacement: step 14, image 1 of 2 Nintendo Switch Pro Controller Buttons / D-Pad Replacement: step 14, image 2 of 2
      • Remove the black ribbon cable from its connector.
      • Only a small amount of force should be needed to remove the ribbon cable.
      Ask FixBot
    4. Nintendo Switch Pro Controller Buttons / D-Pad Replacement: step 15, image 1 of 2 Nintendo Switch Pro Controller Buttons / D-Pad Replacement: step 15, image 2 of 2
      • Remove the trigger buttons from the plastic cover.
      Ask FixBot
    1. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Unscrew the circuit board: step 16, image 1 of 1
      • Use a Phillips screwdriver to remove the two 5 mm-long screw securing the circuit board.
      Ask FixBot
    2. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the board: step 17, image 1 of 2 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the board: step 17, image 2 of 2
      • Remove the circuit board.
      Ask FixBot
    3. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the button(s): step 18, image 1 of 3 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the button(s): step 18, image 2 of 3 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the button(s): step 18, image 3 of 3
      Buy
      • Use your fingers or a pair of tweezers to remove the button(s) you wish to replace.
      Ask FixBot
26 other people completed this guide.
Author
with
James Seidlinger
742 Reputation
1 Guide authored
Cal Poly, Team S11-G2, Regan Fall 2019 Member of Cal Poly, Team S11-G2, Regan Fall 2019
CPSU-REGAN-F19S11G2
5 Members
72 Guides authored
3 Guide Comments
On re-assembly, you may have trouble getting the top circuit board and shoulder button support structure to snap into place. It’s easiest to get the circuit board around the right analog stick hole, and push it all the way down until it is in place, then to secure the shoulder button support structure.
Make sure the “Home” button clear plastic light spreader (a clear irregular circle-shaped piece) is in place on top of the home button assembly, or it will give the home button a “sunken” appearance.
nclee - Reply Share
Worked well, thank you. Had a gooey X button that needed to be cleaned.
Anthony Peacock - Reply Share
What about the sync button? I've been scouring the Switch Pro Controller guide all day but there's nothing on how to remove the sync button! Mine is in really bad shape from having to use paperclips to press it but i can't find a guide to repair it anywhere.
faye kim - Reply Share
Past 24 Hours: 15
Past 7 Days: 153
Past 30 Days: 671
All Time: 46,085
