Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Speakers Do Not Produce Sound
The audio does not project from the speakers clearly
The Audio Slider Is Off
Try pushing the slider to the on position.
Touchscreen Does Not Respond
Gestures to the device's touchscreen has been found unresponsive and/or sluggish
The Screen Could be Dirty.
Try to wipe the screen with a microfiber cloth around the corners of the frame.
Screen Protector Interference
Remove the screen protector (if you are using one) and try to use the screen again.
The Screen Could be Faulty.
Try to replace the screen of the device.
The Circle Pad Does Not Move Smoothly
The circle pad (analog stick/joystick) is too loose, does not return to center, is difficult to move, or does not move at all.
Debris is Obstructing the Circle Pad
If the circle pad is sticky or hard to move, there may be debris lodged within. Follow the guide to remove the circle pad in order to check for any debris that may be causing the issue. Debris can be safely removed with compressed air or a cloth dampened with isopropyl alcohol.
Defective Circle Pad
It is possible that the mechanisms inside the circle pad have broken. If this is the case, you will need to replace it. See the circle pad replacement guide.
The Console Will Not Power On
The Nintendo 3DS XL will not power on.
Drained or Faulty Battery
If the console will not turn on, it is likely your battery is drained or defective. If charging the device does not solve the problem, try replacing the battery. You can remove and replace the battery by following the replacement guide.
Battery Replacement Guide
The NAND Chip is Failing
If the console will turn on but freezes at a black screen without going to the home menu, it's possible that there's a problem with the NAND chip on the motherboard itself, whether it be a loose connection or just general failure. Replacing the motherboard itself could potentially solve the problem. See the motherboard replacement guide.
The Circle Pad is Not Responding
Nothing happens when the circle pad (analog stick/joystick) is moved.
If a quick restart doesn't fix the problem, you may need to replace the circle pad. See the circle pad replacement guide.
A Button Sticks or Requires Excessive Force to Press
A button feels jammed. It may be difficult to push, or it might not pop up after being pressed.
Debris is Obstructing The Button
There may be debris lodged in the button. Follow the replacement guide to remove the button and check inside for any debris or sticky substances. Debris can be safely removed with compressed air or a cloth dampened with isopropyl alcohol.
Button Replacement Guide
A Button is Not Responding.
A specific button or set of buttons does nothing when pressed.
Defective Button
If a quick restart does not fix the problem and the console still does not respond, then the button may need to be replaced. See the button replacement guide.
Unable to Read or Write to the SD Card Memory
The 3DS can't save or access files, and may not even recognize the SD card.
The Card is Not Inserted Correctly
Follow the replacement guide to ensure the SD card is correctly inserted. Make sure the spring lock is properly triggered.
Defective SD Card
The SD card or the SD card reader may be defective. Try inserting the SD card to another device such as a computer or smartphone. If it still does not work, you may need to replace the SD card.
Defective SD Card Reader
If the SD card works in other devices, but not in the 3DS, you will need to replace the SD card reader.
Game Card Not Being Read by the Console
The 3DS does not recognize when a game card has been inserted.
Remove the game card, checking for any debris in the reader port, and reinsert the card.
Defective Game Card Reader
If removing and replacing the game card does not solve the problem, you may have a defective game card reader. Follow the replacement guide to remove and replace it with a working game card reader.
Game Card Reader Replacement
The Directional Pad Sticks or Requires Excessive Force to Press
The directional pad feels jammed. It may be difficult to push, or it might not pop up after being pressed.
Debris is Obstructing The Pad
There may be debris lodged in the pad. Follow the replacement guide to remove the button and check inside for any debris or sticky substances. Debris can be safely removed with compressed air or a cloth dampened with isopropyl alcohol.
Directional Pad Replacement
The Back Cover Will Not Come Off
After unscrewing the two screws on the back cover, it remains very difficult to take off or won’t budge.
The Stylus is Designed to Help You Pry The Cover Off
The lips on the blunt end of the stylus can be hooked into the small slots on each side of the cover and used to pull the cover off. These slots are found on the sides of the 3DS not far from the screws you have to unscrew.
Kobbe Farwick
2,861 Reputation
2 Guides authored
Cal Poly, Team 24-4, Lancaster Spring 2015 Member of Cal Poly, Team 24-4, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G4
4 Members
60 Guides authored
13 Comments
What if the console powers on but does not charge the battery, although it still works and doesn't drain battery when on charger? (battery's not faulty)
emaN - Reply Share
Hello @commonusername, if you are experiencing issues while charging your device with a non-Nintendo charger it may bypass the battery and supply enough current to power the device while turned on. While using an aftermarket charger it is possible that the battery will only charge in sleep mode. What type of outlet are you using and what is the power rating of the plug?
Ryan - Reply Share
My issue is that the 3ds will "turn on" but both screen displays remain black and there is no sound, yet the on light remains blue. No wireless light.
I've heard that a possible reason is a loose or dislodged wifi card. I opened up the back and gained access to the motherboard, yet I can't seem to find a wifi card. Is there on to be found? If so, what am I looking for and where is it?
dewtwo - Reply Share
I have the same issue, but I have not checked it out yet.
Matthew Barker - Reply Share
If it's turning on but there's no displays and no sounds and the light remains blue, it's very possible the issue is the NAND chip failing. I fixed a N3DSXL last year with that same issue and replacing the whole motherboard fixed the problem.
Sean Robinson - Reply Share
Past 24 Hours: 4
Past 7 Days: 41
Past 30 Days: 170
All Time: 7,654
