Introduction
Removing the battery is essential to the removal of other components on the Nintendo 3DS XL. Please remember to have the device powered off when following this guide.
Fully power off the console and flip it upside down.
Remove the game card, headphones, charging cable, stylus, and anything else connected.
Use a JIS 0 screwdriver to loosen the two black captive screws on the back cover.
To reassemble your device, follow these instructions in reverse order. You might need to set the time after installing the new battery.
45 other people completed this guide.
5 Guide Comments
Bonjour,
Tout d’abord merci pour ces explications claires et précises. Toutefois, je me demandais s’il y avait un endroit où l’on peut trouver une batterie officielle Nintendo ? Après quelque recherches je n’ai malheureusement rien trouvé (et comme la console est vieillissante…)?
Bonjour Nicolas Si vous voulez une pièce de nintendo, vous devez être en amérique ou au canada car nintendo ne vend des pièces que dans ces pays, je peux vous donner le site Web pour les états-unis et le canada si vous le souhaitez.
The battery didn't work at all. After replacing the old battery I plugged it in and the charging light would go off after a few seconds. I tried to turn on the 3ds with the new battery in and all that would happen is the blue light would flash for less than a second and the 3ds wouldn't turn on
I too just replaced my battery and had this issue. However, I noticed that when I applied some to heavy pressure on the end of the battery (the end closest to the hinge) it would work. So I just added 2 folded paper sheets (so 4 layers) between the battery and the outer shell. That applied enough pressure for me to use my new battery
