New Nintendo 3DS XL 2015 Game Card Reader Replacement
    1. New Nintendo 3DS XL 2015 Game Card Reader Replacement, Prepare the console: step 1, image 1 of 1
      • Fully power off the console and flip it upside down.
      • Remove the game card, headphones, charging cable, stylus, and anything else connected.
      Ask FixBot
    2. New Nintendo 3DS XL 2015 Game Card Reader Replacement, Loosen the back cover screws: step 2, image 1 of 1
      • Use a JIS 0 screwdriver to loosen the two black captive screws on the back cover.
      • The screws are held in place by captive washers and shouldn't be completely removed.
      Ask FixBot
    3. New Nintendo 3DS XL 2015 Game Card Reader Replacement, Remove the back cover: step 3, image 1 of 1
      • Pry off the back cover and remove it.
      Ask FixBot
    4. New Nintendo 3DS XL 2015 Game Card Reader Replacement: step 4, image 1 of 1
      • Insert an opening tool or the flat end of a spudger into the small notch above the battery and pry the battery out.
      Ask FixBot
    1. New Nintendo 3DS XL 2015 Game Card Reader Replacement, Motherboard: step 5, image 1 of 2 New Nintendo 3DS XL 2015 Game Card Reader Replacement, Motherboard: step 5, image 2 of 2
      • Remove the MicroSD card by pressing it in with your thumbnail until it clicks and partially ejects, then pull it out.
      • Using a JIS #00 screwdriver, remove the six 6mm screws around the edges of the secondary cover.
      Ask FixBot
    2. New Nintendo 3DS XL 2015 Game Card Reader Replacement: step 6, image 1 of 2 New Nintendo 3DS XL 2015 Game Card Reader Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers, carefully pop out the rubber bumpers located at the top side of the 3DS. Removing them will reveal another two 6mm screws. Remove these screws using a JIS #000 as well.
      Ask FixBot
    3. New Nintendo 3DS XL 2015 Game Card Reader Replacement: step 7, image 1 of 3 New Nintendo 3DS XL 2015 Game Card Reader Replacement: step 7, image 2 of 3 New Nintendo 3DS XL 2015 Game Card Reader Replacement: step 7, image 3 of 3
      • To separate the cover, carefully lift it up and away from the hinges (in order to clear the headphone port), then pivot it towards the hinges to expose the circuit boards.
      • Don't fully remove the cover yet, or you may damage the delicate ribbon cable that still connects it to the motherboard.
      Ask FixBot
    4. New Nintendo 3DS XL 2015 Game Card Reader Replacement, Disconnect and remove the back cover: step 8, image 1 of 1
      • Use the flat end of a spudger to disconnect the shoulder button cable press connectors.
      • Remove the back cover.
      Ask FixBot
    5. New Nintendo 3DS XL 2015 Game Card Reader Replacement: step 9, image 1 of 1
      • Use tweezers to flip up the small, hinged locking flap in order to unlock the ZIF connector securing the Circle Pad ribbon.
      • The cable folds over itself and enters the ZIF connector from the left side, but the connector's locking flap flips up from the right side. A common error here is to try pulling up on the same side as the cable is on, when that could break the connector.
      • Slide the ribbon out of the ZIF connector.
      • It may be easier to unscrew and remove the Circle Pad first, then try disconnecting the cable. Similarly, when reinstalling the Circle Pad, you can reconnect the cable first and then put the unit back into place.
      Ask FixBot
    6. New Nintendo 3DS XL 2015 Game Card Reader Replacement: step 10, image 1 of 1
      • Using a JIS #000 screwdriver, remove the two 8 mm screws securing the circle pad.
      Ask FixBot
    7. New Nintendo 3DS XL 2015 Game Card Reader Replacement: step 11, image 1 of 1
      • Lift the circle pad casing upward to remove it. There will be some friction, but it should not require excessive force.
      Ask FixBot
    8. New Nintendo 3DS XL 2015 Game Card Reader Replacement: step 12, image 1 of 1
      • Locate the gold terminal plug with a red cable at the top left of the motherboard. Using your fingers, carefully pull the plug straight upward to remove.
      • Use a pair of tweezers to disconnect the single ribbon connector.
      • Don't do what we did -- be very careful not to pull on the red cable.
      Ask FixBot
    9. New Nintendo 3DS XL 2015 Game Card Reader Replacement: step 13, image 1 of 3 New Nintendo 3DS XL 2015 Game Card Reader Replacement: step 13, image 2 of 3 New Nintendo 3DS XL 2015 Game Card Reader Replacement: step 13, image 3 of 3
      • Using tweezers, gently pull the four marked ribbons out of the ZIF connectors along the sides of the motherboard.
      • These ZIF connectors are held in place by friction and do *not* have locks—lifting the flaps on these connectors will break them! Be careful disconnecting the upper red connector (some people report that it has a clamp while others do not). Double check if your model has a clamp, and when you disconnect the ribbon cable, be excessively gentle.
      • Three of the ribbon connectors have plastic clamping flaps that cover the ribbon to prevent slippage. Use the tweezers to flip them up before ribbon removal.
      • This one ribbon connector may also have a plastic clamping flap, but it's not like the others, rather it's similar to the one used for the Circle Pad. Gently flip up the flap on the side opposite the ribbon cable to remove the cable.
      • This connector was previously listed among the ones that do not have locks, however on most if not all systems, it actually does have one. Trying to remove or reinsert this cable without unlocking it will damage the cable, requiring a replacement of the Touch Screen's digitizer. Fortunately, the LCD uses other ZIF connectors, so that should still be fine.
      • If, on your system, this connector does not have a lock after all, do not pull up on the flap! It should come up easily; if it doesn't, it probably isn't meant to lock, but instead just hold the cable in with friction. In that case, try gently pulling the cable out of the connector.
      • When reassembling the device, be sure to flip the ZIF clamps back down.
      • While the SD card reader is shown as removed in this photo, it is optional for the removal of the motherboard.
      Ask FixBot
    10. New Nintendo 3DS XL 2015 Game Card Reader Replacement: step 14, image 1 of 1
      • Using a JIS #000 screwdriver, remove six 4mm screws along the edges of the motherboard.
      Ask FixBot
    11. New Nintendo 3DS XL 2015 Game Card Reader Replacement: step 15, image 1 of 2 New Nintendo 3DS XL 2015 Game Card Reader Replacement: step 15, image 2 of 2
      • Carefully pivot the motherboard 90 degrees toward the hinges to reveal two more ZIF connectors on the underside of the motherboard.
      • Both have latches that must be flipped up. The left, longer latch is black; the right, shorter one is white. Flip up the flaps, slide the ribbons out and remove the motherboard.
      • Note which way the ribbons slide into their connectors carefully, as they are different - specifically the longer screen ribbon cable, which needs the pins facing down/the black plastic part facing up for the top screen to function.
      Ask FixBot
    1. New Nintendo 3DS XL 2015 Game Card Reader Replacement, Game Card Reader: step 16, image 1 of 1
      • Remove five 5mm screws from the game card reader panel using a JIS #000 screwdriver.
      • The game card reader can now be removed and replaced.
      Ask FixBot
21 other people completed this guide.
Jacky Loh
453 Reputation
1 Guide authored
Cal Poly, Team 24-4, Lancaster Spring 2015 Member of Cal Poly, Team 24-4, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G4
4 Members
60 Guides authored
11 Guide Comments
I bought a replacement card slot and it has the small flat cable connector not on the top right like on your photos (and in my New 3DS XL) but on the right oriented to the right, see https://abload.de/img/cardslot_sintech_2....
Does anyone have any insight on different revisions of the card slot? Where can I buy a card slot like the one in the photos here? Thanks in advance.
Uwe - Reply Share
Will I be able to complete this process with a PH00? I don’t have have a PH000 or any JIS screwdrivers.
Luke - Reply Share
You don't have to take the entire board out to replace this
Skyler Davis - Reply Share
Are you sure?
Kevin Canto - Reply Share
That is true. I just changed mine easily without removing the whole mainboard..
battlepengu - Reply Share
Past 24 Hours: 25
Past 7 Days: 162
Past 30 Days: 695
All Time: 55,893
