Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Nikon Coolpix p7700 Troubleshooting
Welcome to our troubleshooting page of the Nikon P7700. This camera was released in September of 2011.
Screen won't turn on or is cracked
The screen does not display images which could mean it is broken or cracked.
Restart Camera
hold the on/off button and the screen could start right up.
Cracked screen
The screen could be cracked or badly damaged. If there are visible cracks and you are positive the screen is on you may have to replace the screen with a Vari-Angle TFT-LCD with Anti-reflection coating.
Focusing screen is broken
Your camera turns on but the images are scratched but the lens is not damaged.
Clean Lens
The lens could be dirty and could be easily cleaned. Get an old rag or shirt with some cleaning material for glass and rub until clean.
Cracked Focusing screen
The screen inside may be shattered, cracked or malfunctioning, and you will have to replace it
Cannot use Selecting Wheel
You are trying to select something and the wheel is not responsive.
Make sure camera is on
It is possible the camera turned off, make sure it is on.
Restart Camera
If the wheel is not responding, try to restart the camera
Wheel is broken
If the camera is on, and you restarted it then it is broken and you will have to replace it.
Nikon COOLPIX P7700 Multi Selector Wheel Replacement
Back Casing
If the back casing is cracked or shattered from a drop or spill you may have to replace it.
Make sure it is not just a scratch
The casing could be scratched and can wash off or be left alone
Cracked or Shattered
If the casing is broken or cracked you will have to replace it with another.
Nikon COOLPIX P7700 Back Casing Replacement
Reflective Mirror Broken
The camera takes shattered pictures or weird orientation you may have to look into replacing it.
Restart camera
If the camera is taking not quality pictures, try restarting the camera by holding the on/off button to turn off and hold again to turn on.
Check battery life
Camera may be misbehaving because the battery is low. Check the battery life. If the batter is low, replace it or recharge it.
Still cracked or shattered picture?
If the quality is still not optimal, you may have to replace the mirror inside.
Matthew Seidel
154 Reputation
1 Guide authored
1 Comment
I love my camera and until now I have had no problems with the hundreds of photographs that I have taken. Then a couple of weeks ago, I stopped and took a couple of pictures of rainbows. When I hooked my camera up to my computer, the photographs were not there. I checked my camera and the photos were not there either.
Last night I took more than twenty photographs at a family get together. I checked the photographs as I was leaving and all were in the camera as they should be.
This morning, I found the two missing pictures of the rainbow on my camera but none of the party last night. What is going on?
Robert S. Davis - Reply Share
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 46
All Time: 2,098
