Nikon COOLPIX P7700 Multi Selector Wheel Replacement
  1. Nikon COOLPIX P7700 Multi Selector Wheel Replacement, Back Casing: step 1, image 1 of 2 Nikon COOLPIX P7700 Multi Selector Wheel Replacement, Back Casing: step 1, image 2 of 2
    • Turn camera to the left side and remove the two 4.3 mm black side screws using the Phillips #00 screwdriver.
    • Remove the side panel.
    Ask FixBot
  2. Nikon COOLPIX P7700 Multi Selector Wheel Replacement: step 2, image 1 of 1
    • Open the touch screen, and remove the three 4.3 mm black screws inside using the Phillips #00 screwdriver.
    Ask FixBot
  3. Nikon COOLPIX P7700 Multi Selector Wheel Replacement: step 3, image 1 of 1
    • Remove the 4.3 mm black screw on top of the camera, right above where the screen folds out. Use the Phillips #00 screwdriver.
    Ask FixBot
  4. Nikon COOLPIX P7700 Multi Selector Wheel Replacement: step 4, image 1 of 1
    • Remove the two 4.3 mm black screws on the right side of the camera using the Phillips #00 screwdriver.
    Ask FixBot
  5. Nikon COOLPIX P7700 Multi Selector Wheel Replacement: step 5, image 1 of 1
    • Remove the 4.3 mm black screws on the bottom of the camera using the Phillips #00 screwdriver.
    Ask FixBot
  6. Nikon COOLPIX P7700 Multi Selector Wheel Replacement: step 6, image 1 of 2 Nikon COOLPIX P7700 Multi Selector Wheel Replacement: step 6, image 2 of 2
    • Begin separating the camera into two parts.
    • It is okay to remove the orange ribbon. This will be easily put back into place when re-assembling.
    Ask FixBot
  7. Nikon COOLPIX P7700 Multi Selector Wheel Replacement: step 7, image 1 of 1
    • Remove the back casing.
    Ask FixBot
  8. Nikon COOLPIX P7700 Multi Selector Wheel Replacement, Multi Selector Wheel: step 8, image 1 of 1
    • Remove the four 4.3 mm screws located on the far right metal plate. Use the Phillips #00 screwdriver.
    Ask FixBot
  9. Nikon COOLPIX P7700 Multi Selector Wheel Replacement: step 9, image 1 of 2 Nikon COOLPIX P7700 Multi Selector Wheel Replacement: step 9, image 2 of 2
    • Remove and replace wheel.
    Ask FixBot
8 other people completed this guide.
Dustin Wahl
808 Reputation
4 Guides authored
8 Guide Comments
Step 9: I believe that the multi-selector wheel component is soldered, 3 wires just visible in the photo for step 8. This will surely add to the time taken and difficulty.
I have a problem with this component. Firstly it's almost impossible to obtain the replacement parts, but if I could this guide would be invaluable; pictures are worth a thousand words! Thanks.
basstrom - Reply Share
where can I get the item ( wheel ) ?
Best regards and thank you for the good explanation
fiteluetkehoff - Reply Share
Where i can find this wheel for replacement?
skromnjagaserj - Reply Share
See my comment above, for spray cleaning the wheel without any replacement. Unless your wheel is brokwn, you can try my suggestion. It works.
JY - Reply Share
Please see my comment on the "general" method of fixing the wheel (using fast-drying contact cleaner) without ANY component replacement or unscrewing. It works really well but you may have to do it 1-3 times until all the dirt inside the wheel mechanism is removed. I have managed to restore my P7700 (after "fixing" the erratic Control Wheel and the dis-obedient Play button). Since then I have used the same method to fix the control wheel on my Samsung EX-1 camera (the control wheel was replaced twice by Samsung but the problem came back after a year or so). The root cause is probably a weak control wheel design (maybe tiny metal springs rotating over a base-plate with printed circuits). Now I know how to save money and trouble (for any compact camera with a similar control wheel design).
JY - Reply Share
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 75
All Time: 6,351
