Coolpix Won't Turn On
Hold Switch On
Drained/Bad Battery
If the camera won't turn on the mostly likely cause is defective batteries. Make sure batteries are charged and the battery contacts are clean. The battery could possibly be dead; to verify this, test the battery with a voltmeter. If a voltmeter is not available there are certain distinct signs that indicate a dead or dying battery. If the battery holds its charge for only a short time or if the battery doesn't charge, it needs to be replaced. Nikon Coolpix P4 Battery Replacement
Bad Display
Cracked
If the crack hinders normal operation, the screen must be replaced. Nikon Coolpix P4 LCD Screen Replacement
Internal Issue
There may be loose or broke wires inside, this is more likely if the camera has been recently dropped or been treated roughly. Nikon Coolpix P4 LCD Screen Replacement
Bad Motherboard
If the software is not working, the problem may lie in a bad motherboard, which would need to be replaced. Nikon Coolpix P4 Motherboard Replacement
Images Appear To Be Distorted
Out Of Focus
When taking pictures, make sure press shutter button half way down to allow camera to focus properly.
Dirty Lens
Check to see if the camera lens appears grimy or has visible dirt on it. If needed wipe with a cotton swab doused in cleaning alcohol.
Flash Not Functioning
Flash Settings
Go into the Menu, select Setup, then Reset All
Bulb
Flash bulb may be burnt out, which would require replacement. Nikon Coolpix P4 Flash Bulb Replacement
Lens Issues
Battery
Batteries may be critically low. Replace then turn camera on and off. Nikon Coolpix P4 Battery Replacement
Blocked Lens/Jammed
Dust or other similar particles can block the lens from retracting. This may require professional help to remove.
Broken Lens
If the lens is broken it will need to be replaced. Nikon Coolpix P4 Lens Replacement
Jimmy Carson
19 Reputation
0 Guides authored
Cal Poly, Team 8-5, Regan Spring 2011 Member of Cal Poly, Team 8-5, Regan Spring 2011
CPSU-REGAN-S11S8G5
4 Members
60 Guides authored
2 Comments
Hi my Nikon Coolpix turns on, lens comes out partially then detract and makes funny noise then says on view finder turn camera off, remove lens cap, ( already off) turn camera on. The batteries are ok and fully charged. Any ideas please
paulthrossell - Reply Share
Hi, can anyone please help with my issue? This video shows it https://www.youtube.com/watch?v=BjSG8OIj...
Bobby Lashley - Reply Share
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 21
All Time: 9,172
