Nikon Coolpix P4 LCD Screen Replacement
    1. Nikon Coolpix P4 LCD Screen Replacement, Battery: step 1, image 1 of 1
      • Flip the camera upside down (have the side with the buttons facing away from you)
      • Look for the side with the triangle icon with three lines in it, this is the battery door. Add pressure and slide this door slightly until it clicks and pops open.
      Ask FixBot
    2. Nikon Coolpix P4 LCD Screen Replacement: step 2, image 1 of 1
      • Once the door clicks, you can open it to reveal the slots holding the memory card and the battery.
      • Focusing on the larger slot, this holds the battery. Push the orange tab away from the slot, this will eject the old battery if one was previously inside.
      • Once this slot is open, you can place the new battery inside.
      • Make sure to close the orange tab to secure it in place!
      Ask FixBot
    1. Nikon Coolpix P4 LCD Screen Replacement, LCD Screen: step 3, image 1 of 1
      • Remove the four 2.2 mm screws located on the bottom of the camera.
      Ask FixBot
    2. Nikon Coolpix P4 LCD Screen Replacement: step 4, image 1 of 2 Nikon Coolpix P4 LCD Screen Replacement: step 4, image 2 of 2
      • Remove the two 2.9 mm screws from the side panel.
      • Remove the side panel.
      Ask FixBot
    3. Nikon Coolpix P4 LCD Screen Replacement: step 5, image 1 of 3 Nikon Coolpix P4 LCD Screen Replacement: step 5, image 2 of 3 Nikon Coolpix P4 LCD Screen Replacement: step 5, image 3 of 3
      • Remove the two 5 mm screws from the right side panel.
      • Remove the panel from the right side.
      • Remove the single 2.1 mm screw set underneath the panel.
      Ask FixBot
    4. Nikon Coolpix P4 LCD Screen Replacement: step 6, image 1 of 1
      • Remove the two 4.8 mm screws attaching the back panel to the body on the left side.
      Ask FixBot
    5. Nikon Coolpix P4 LCD Screen Replacement: step 7, image 1 of 1
      • Gently pull off the back cover.
      Ask FixBot
    6. Nikon Coolpix P4 LCD Screen Replacement: step 8, image 1 of 2 Nikon Coolpix P4 LCD Screen Replacement: step 8, image 2 of 2
      • Remove the three 4.8 mm screws from the A/V out tab on the left side.
      • Remove the tab.
      Ask FixBot
    7. Nikon Coolpix P4 LCD Screen Replacement: step 9, image 1 of 1
      • Remove the two 4.6 mm screws attaching the front panel to the body on the left side.
      Ask FixBot
    8. Nikon Coolpix P4 LCD Screen Replacement: step 10, image 1 of 1
      • Flip up the front panel.
      • Potential for device damage. There should be wires still attaching the panel to the body. DO NOT TRY TO PULL OFF COMPLETELY.
      Ask FixBot
    9. Nikon Coolpix P4 LCD Screen Replacement: step 11, image 1 of 1
      • Remove the 2.2 mm screw.
      • Remove the 2.9 mm screw.
      • Remove the 2.1 mm screw.
      Ask FixBot
    10. Nikon Coolpix P4 LCD Screen Replacement: step 12, image 1 of 1
      • Carefully pull the orange LCD connector up and out of the port.
      • Be careful to pull vertically while pushing the black tab upwards
      Ask FixBot
    11. Nikon Coolpix P4 LCD Screen Replacement: step 13, image 1 of 1
      • Remove the 3.1 mm screw below the LCD.
      Ask FixBot
    12. Nikon Coolpix P4 LCD Screen Replacement: step 14, image 1 of 1
      • Carefully pull out the plug connecting the LCD to the motherboard.
      Ask FixBot
    13. Nikon Coolpix P4 LCD Screen Replacement: step 15, image 1 of 1
      • Remove the LCD from the camera body.
      Ask FixBot
Luke Baumann
128 Reputation
5 Guides authored
Cal Poly, Team 8-5, Regan Spring 2011 Member of Cal Poly, Team 8-5, Regan Spring 2011
CPSU-REGAN-S11S8G5
4 Members
60 Guides authored
1 Guide Comment
Where did you get the screen?
jharrison - Reply Share
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 29
All Time: 3,712
