Nikon Coolpix P4 Motherboard Replacement
  1. Nikon Coolpix P4 Motherboard Replacement, Battery: step 1, image 1 of 1
    • Flip the camera upside down (have the side with the buttons facing away from you)
    • Look for the side with the triangle icon with three lines in it, this is the battery door. Add pressure and slide this door slightly until it clicks and pops open.
    Ask FixBot
  2. Nikon Coolpix P4 Motherboard Replacement: step 2, image 1 of 1
    • Once the door clicks, you can open it to reveal the slots holding the memory card and the battery.
    • Focusing on the larger slot, this holds the battery. Push the orange tab away from the slot, this will eject the old battery if one was previously inside.
    • Once this slot is open, you can place the new battery inside.
    • Make sure to close the orange tab to secure it in place!
    Ask FixBot
  3. Nikon Coolpix P4 Motherboard Replacement, LCD Screen: step 3, image 1 of 1
    • Remove the four 2.2 mm screws located on the bottom of the camera.
    Ask FixBot
  4. Nikon Coolpix P4 Motherboard Replacement: step 4, image 1 of 2 Nikon Coolpix P4 Motherboard Replacement: step 4, image 2 of 2
    • Remove the two 2.9 mm screws from the side panel.
    • Remove the side panel.
    Ask FixBot
  5. Nikon Coolpix P4 Motherboard Replacement: step 5, image 1 of 3 Nikon Coolpix P4 Motherboard Replacement: step 5, image 2 of 3 Nikon Coolpix P4 Motherboard Replacement: step 5, image 3 of 3
    • Remove the two 5 mm screws from the right side panel.
    • Remove the panel from the right side.
    • Remove the single 2.1 mm screw set underneath the panel.
    Ask FixBot
  6. Nikon Coolpix P4 Motherboard Replacement: step 6, image 1 of 1
    • Remove the two 4.8 mm screws attaching the back panel to the body on the left side.
    Ask FixBot
  7. Nikon Coolpix P4 Motherboard Replacement: step 7, image 1 of 1
    • Gently pull off the back cover.
    Ask FixBot
  8. Nikon Coolpix P4 Motherboard Replacement: step 8, image 1 of 2 Nikon Coolpix P4 Motherboard Replacement: step 8, image 2 of 2
    • Remove the three 4.8 mm screws from the A/V out tab on the left side.
    • Remove the tab.
    Ask FixBot
  9. Nikon Coolpix P4 Motherboard Replacement: step 9, image 1 of 1
    • Remove the two 4.6 mm screws attaching the front panel to the body on the left side.
    Ask FixBot
  10. Nikon Coolpix P4 Motherboard Replacement: step 10, image 1 of 1
    • Flip up the front panel.
    • Potential for device damage. There should be wires still attaching the panel to the body. DO NOT TRY TO PULL OFF COMPLETELY.
    Ask FixBot
  11. Nikon Coolpix P4 Motherboard Replacement: step 11, image 1 of 1
    • Remove the 2.2 mm screw.
    • Remove the 2.9 mm screw.
    • Remove the 2.1 mm screw.
    Ask FixBot
  12. Nikon Coolpix P4 Motherboard Replacement: step 12, image 1 of 1
    • Carefully pull the orange LCD connector up and out of the port.
    • Be careful to pull vertically while pushing the black tab upwards
    Ask FixBot
  13. Nikon Coolpix P4 Motherboard Replacement: step 13, image 1 of 1
    • Remove the 3.1 mm screw below the LCD.
    Ask FixBot
  14. Nikon Coolpix P4 Motherboard Replacement: step 14, image 1 of 1
    • Carefully pull out the plug connecting the LCD to the motherboard.
    Ask FixBot
  15. Nikon Coolpix P4 Motherboard Replacement: step 15, image 1 of 1
    • Remove the LCD from the camera body.
    Ask FixBot
  16. Nikon Coolpix P4 Motherboard Replacement, Motherboard: step 16, image 1 of 1
    • Remove the two screws on the opposite sides of the flash.
    Ask FixBot
  17. Nikon Coolpix P4 Motherboard Replacement: step 17, image 1 of 1
    • Remove the two 2.9 mm screws on the right side of the camera.
    Ask FixBot
  18. Nikon Coolpix P4 Motherboard Replacement: step 18, image 1 of 1
    • Remove the four screws on the bottom of the camera.
    Ask FixBot
  19. Nikon Coolpix P4 Motherboard Replacement: step 19, image 1 of 1
    • Remove the seven 2.8 mm screws from the back of the camera.
    Ask FixBot
  20. Nikon Coolpix P4 Motherboard Replacement: step 20, image 1 of 1
    • Detach the cable that connects the lens to the left side of the motherboard.
    • Firmly grasp the base of the cable and gently pull it from the socket.
    Ask FixBot
  21. Nikon Coolpix P4 Motherboard Replacement: step 21, image 1 of 1
    • Remove the right panel.
    Ask FixBot
  22. Nikon Coolpix P4 Motherboard Replacement: step 22, image 1 of 1
    • Remove the 2.8 mm screw from the top of the camera.
    Ask FixBot
  23. Nikon Coolpix P4 Motherboard Replacement: step 23, image 1 of 1
    • Remove the three 2.8 mm screws from the motherboard.
    • Detach the orange tab with the foam on top.
    • It should click out of place.
    Ask FixBot
  24. Nikon Coolpix P4 Motherboard Replacement: step 24, image 1 of 1
    • Remove the motherboard by pulling it up and out of the port.
    Ask FixBot
  25. Nikon Coolpix P4 Motherboard Replacement: step 25, image 1 of 1
    • Carefully remove the tab that connects the flash to the motherboard from the port by gently pulling the connector to the right and out of its port.
    Ask FixBot
  26. Nikon Coolpix P4 Motherboard Replacement: step 26, image 1 of 1
    • Fully remove the motherboard from the camera body.
    Ask FixBot
Luke Baumann
128 Reputation
5 Guides authored
Cal Poly, Team 8-5, Regan Spring 2011 Member of Cal Poly, Team 8-5, Regan Spring 2011
CPSU-REGAN-S11S8G5
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 18
All Time: 2,938
