Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device will not turn on
No matter what you do, you can't get your Mr. Rice SC-887 to heat up even if the cook button is in place and the outlet works.
Power cord is broken
If your power cord is broken, frayed, or cut you will need to replace the power cord completely in order to restore power for your Mr. Rice SC-887. Your cord could still be the problem even if it is not broken, frayed, or cut due to an internal problem with the power cord.
Tatung TAC-6G Power Cord Replacement
Faulty internal circuitry is corrupted
Are you still not getting power to your Mr. Rice SC-887 and your cord is connected properly? Your internal circuitry could be corrupt and will need to be closely examined and restored in order to generate power back to your rice cooker.
Power light does not work but still heats
If your Mr. Rice SC-887 is working properly but the indicator light is not working, your rice cooker's light might be out.
Light is burnt out
If your rice cooker power light is not working but the cooker is heating properly, there is a possibility it is burnt out. To test, you can turn the cooker over and examine the bulb by "moving the wires around" to see if you have a shortage. If the light does not come on, you will need to replace the bulb.
Tatung TAC-6G Light Element Replacement
Light is not connected to the circuitry
If your light indicator is not working but the Mr. Rice SC-887 is heating properly then the light-wires may not be connected to the circuitry. If replacing the indicator bulb doesn't work you have a shortage in your indicator cords.
Device doesn't become hot when on
The rice cooker is on with appropriate indicator light, but the device is not heating properly
Heating Element is detached from internal circuitry
If you are getting power to your Mr. Rice SC-887 but it is not heating properly, then your heating plate might be detached from your internal circuitry. You will need to test your circuitry for power to the heating plate on the rice cooker.
Heating Element is broken
If your Mr. Rice Cooker SC-887 is not heating properly, your hot plate could be broken. You will need to replace the hot plate springs in order to fix this heating problem.
Tatung TAC-6G Heating Element Replacement
Device is too hot
No matter what you do, your device is too hot
Heating Element is broken and will not stay down
If your Mr. Rice Cooker SC-887 is cooking properly but the heat will not decrease after you take the rice bowl out, your hot plate could be broken. You will need to replace the hot plate springs in order to fix this heating problem.
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 38
All Time: 1,236
