Tatung TAC-6G Light Element Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
95
All Time:
1,316
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
The device contains small lights that indicate whether the rice is cooking or being kept warm. In this guide we will the expose the light bulb circuitry to check if it is broken and replace the light bulbs if necessary.
Tools
    1. Tatung TAC-6G Light Element Replacement, Light Element: step 1, image 1 of 1
      • Start with the device standing upright.
      Ask FixBot
    2. Tatung TAC-6G Light Element Replacement: step 2, image 1 of 1
      • Remove the 11mm Phillips screw from below the power component panel.
      Ask FixBot
    3. Tatung TAC-6G Light Element Replacement: step 3, image 1 of 1
      • Pull the panel away from the rice cooker.
      • Remove the 9mm Phillips screw from behind the power component dashboard that is connected to the light plate.
      Ask FixBot
    4. Tatung TAC-6G Light Element Replacement: step 4, image 1 of 1
      • Pull the light plate from the power component panel.
      Ask FixBot
    5. Tatung TAC-6G Light Element Replacement: step 5, image 1 of 1
      • Flip the rice cooker device upside down.
      Ask FixBot
    6. Tatung TAC-6G Light Element Replacement: step 6, image 1 of 2 Tatung TAC-6G Light Element Replacement: step 6, image 2 of 2
      • Remove the one 7mm Phillips screw from the side of the brass panel
      • Lift the brass plate off of the device and set it aside.
      Ask FixBot
    7. Tatung TAC-6G Light Element Replacement: step 7, image 1 of 1
      • Remove the 7mm Phillips screw holding the white and maroon colored wires that are connected to the heating element.
      Ask FixBot
    8. Tatung TAC-6G Light Element Replacement: step 8, image 1 of 1
      • Remove the 10mm Phillips screw that connects the white, blue and black wires to the white plastic piece in the corner of the device.
      Ask FixBot
    9. Tatung TAC-6G Light Element Replacement: step 9, image 1 of 1
      • Remove the 7mm Phillips screw that connects two white wires and one red wire to the heating "warm" switch.
      Ask FixBot
    10. Tatung TAC-6G Light Element Replacement: step 10, image 1 of 1
      • Using your hand, pull out the light plate with the maroon red and black wires.
      Ask FixBot
    11. Tatung TAC-6G Light Element Replacement: step 11, image 1 of 1
      • Replace the light plate dashboard.
      Ask FixBot
1 Guide Comment
Reverse the steps for reassembly.
Tom Anderson - Reply Share
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 95
All Time: 1,316
