Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Phone Will Not Turn On
The phone will not turn on when you hold down the power button for at least 5 seconds.
Drained/Defective Battery
If your phone won't turn on and you haven't used it recently, then the battery might be drained. Plug your phone into its charger and attempt to turn it on after an hour has passed. If the phone still cannot turn on, then the battery might not be able to charge anymore, meaning it might be defective and must be replaced.
Temperature Too Hot
If the phone is left out in the sun or a hot environment for too long, the internal temperature may become too hot. Allow the phone to cool down before trying to turn it on.
Defective Display
The phone might appear to not be turning on because the display is damaged. If it can still generate sounds and be detected by other devices, then the display is likely faulty and you might need to replace the screen.
Screen is Not Working
The screen does not respond when touched.
Screen is Cracked
There are many causes to cracked screens such as dropping it, kicking it, or having another item fall on top of it. If the phone screen is cracked, the display or touch functions may become inoperative, meaning it must be replaced.
Phone is Frozen
If the phone is unable to change what it is displaying, but was working previously, then the phone might be frozen. You might be able to fix it by rebooting it: simultaneously hold the power and volume buttons until the phone screen goes black, then release both buttons.
Temperature Too Hot
Phone Logic Board Damaged
The phone's logic board may be damaged causing the screen to become inoperative. Check with the manufacturer to determine if the logic board needs to be replaced or repaired.
Phone Shuts Off Randomly
The phone does not stay turned on when in use.
Drained Battery
If the phone shuts off unexpectedly, check the charge level of the phone to see if it is nearing 0%. The phone will shut off to prevent component damage at these critically low battery levels. Be sure to plug in your phone into its charger and charge for about an hour.
Temperature Too Hot
Software is Malfunctioning
The phone's software might be functioning incorrectly and tampering with the phone's memory, causing it to shut off unexpectedly. You can possibly fix this by rebooting it, where you simultaneously hold the power and volume buttons until the phone screen goes black, then release both buttons.
Defective Battery
If your phone shuts off unexpectedly and the charge level of the phone is well above 0% or the charge level does not increase when attempting to charge it, the battery might be defective. In this case, the battery has to be replaced.
Phone Freezes or Becomes Slow
The phone is running slower than usual or is frozen.
Phone is Being Overworked
Having too many applications open can overwhelm the phone and cause it to be slow or freeze. Hold the home button until a list of running applications appears. Swipe right on all open applications to close them.
Phone is Frozen
Temporarily frozen phones can sometimes be fixed by rebooting them. Simultaneously hold the power and volume buttons until the phone screen goes black, then release both buttons. This will clear temporarily stored data to reduce the working load on the phone.
If rebooting didn't work you can also try a Factory Reset.
**Warning** This step will erase all saved data. It is recommended to do a full backup prior to attempting this step. Performing a factory reset will remove all data from the phone and return it to default new state.
To perform the factory reset, hold down the power button and the volume buttons simultaneously until the screen turns black. Once the phone reboots select "recover". Then select settings, then privacy, and finally select factory data reset.
Allow the phone to perform the reset and clear all stored data.
Phone Will Not Connect to WiFi
The use of WiFi is limited or not working.
WiFi Switch Turned Off
Under settings, make sure the phone has WiFi turned on. If you are in airplane mode, WiFi will be turned off.
WiFi is Unavailable
Make sure WiFi is available in a direct nearby area.
WiFi Password Incorrect
Make sure the WiFi network password is stored in the phone correctly.
Settings Need to be Refreshed
The phone may need to be rebooted in order to refresh its settings. Simultaneously hold the power and volume buttons until the phone screen goes black, then release both buttons. Once turned on, attempt to reconnect to WiFi.
Phone Will Not Connect to Bluetooth
The use of Bluetooth is limited or not working.
Bluetooth Turned Off
Under settings, make sure the phone has Bluetooth turned on. If you are in airplane mode, Bluetooth will be turned off.
Bluetooth Equipped Device Turned Off
The device you are trying to connect to may be out of range or not receiving connections. Make sure the Bluetooth device is turned on and accepting connections.
Bluetooth Password Stored Incorrectly
Make sure the Bluetooth password for the device you are attempting to connect to is stored correctly. Generic devices generally have a password of "0000" or "1234", however, some devices have passwords set for the specific device. Consult the manufacturer for this password.
The phone may need to be rebooted in order to refresh its settings. Simultaneously hold the power and volume buttons until the phone screen goes black, then release both buttons. Once turned on, attempt to reconnect to Bluetooth.
Phone Speaker Not Working
There is limited to no volume coming out of the phone.
Volume Set on Mute
Make sure the phone volume is turned on by clicking the volume up button on the right side of the phone.
Defective Speaker
If the phones says that the volume is turned up but is still not working, the phone speaker may be defective and may need replacement. Depending on which speaker is not working, you may need to perform an earpiece speaker replacement, an external speaker replacement, or both.
Defective Headphone Jack
The phone headphone jack may be defective causing the phone to disable the external speaker. Headphone jack replacement may be necessary.
Frozen Phone
The phone may simply be frozen. This can sometimes be fixed by rebooting it. Simultaneously hold the power and volume buttons until the phone screen goes black, then release both buttons.
Applications Fail to Load
The phone is unable to open or load applications.
Overuse of Applications
If too many applications are open, then phone performance may decrease. Hold the home button until a list of running applications appears. Swipe right on all open applications to close them. This reduces the working load on the phone.
Frozen Phone
The phone may simply be frozen. This can sometimes be fixed by rebooting it. Simultaneously hold the power and volume buttons until the phone screen goes black, then release both buttons. This will clear temporarily stored data to reduce the working load on the phone.
Application Updates Needed
Out of date applications can cause the phone to slow down, sometimes this can be fixed by updating your applications.
**It is recommended to complete this step while connected to WiFi**
To update your applications click settings under the phone menu. Then select "applications" and enter the "all applications" list. From here select the applications you would like to update. Once updates are selected, allow the phone to update the applications, this may take significant time and may slow the phone down in the process. Afterwards your applications will be updated to the most current software.
Applications are Still Having Problems Running
By uninstalling and re-installing applications that fail to load, some running problems may be resolved.
Click settings under the phone menu. Then select "applications" and enter the "all applications" list. From here select the applications that you wish to uninstall.
Re-install by entering the Android Market and searching for the applications you wish to install. Once the desired application is found click the install button.
Once installed try running the application and look for application running issues. If none are found proceed to use the application.
Author
with
Jacob Syage
284 Reputation
2 Guides authored
Cal Poly, Team 8-40, Amido Winter 2015 Member of Cal Poly, Team 8-40, Amido Winter 2015
CPSU-AMIDO-W15S8G40
5 Members
108 Guides authored
1 Comment
a phone that cost this much should last longer, my wife has the razor and it is locking up and the BATTERY over heating
PNONE IS ONLY 2 1/2 MONTHS OLD
nyboricua1 - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 20
All Time: 1,983
