Up to 20% off select tools
Motorola RAZR Maxx HD Screen Replacement
Views: 3.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
107
All Time:
3,519
Comments: 0
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide involves the removal of various small screws and parts so make sure you are in a clean and organized environment to avoid the loss of any components.
    1. Motorola RAZR Maxx HD Screen Replacement, Screen Removal: step 1, image 1 of 2 Motorola RAZR Maxx HD Screen Replacement, Screen Removal: step 1, image 2 of 2
      • Use the Torx T5 Screwdriver to remove two 5.0 mm screws at the bottom of the phone.
      Ask FixBot
    2. Motorola RAZR Maxx HD Screen Replacement: step 2, image 1 of 2 Motorola RAZR Maxx HD Screen Replacement: step 2, image 2 of 2
      • To remove the SIM card, use an unfolded paperclip to press down on the metal plate on the left side of the phone until it pops up.
      Ask FixBot
    3. Motorola RAZR Maxx HD Screen Replacement: step 3, image 1 of 2 Motorola RAZR Maxx HD Screen Replacement: step 3, image 2 of 2
      • Gently push the screen toward the top edge of the phone and tilt the screen to reveal the black flex cables.
      • Do NOT remove the screen all the way or the flex cables will be damaged.
      Ask FixBot
    4. Motorola RAZR Maxx HD Screen Replacement: step 4, image 1 of 2 Motorola RAZR Maxx HD Screen Replacement: step 4, image 2 of 2
      • Release the two black ribbon flex cables by gently pulling up on the connection using the spudger. Then lift the screen to remove.
      • Make sure to remove the flex cables before completely removing the screen.
      • When reassembling, align the white bands on the edge of the screen so that a connection is made.
      Ask FixBot
    1. Motorola RAZR Maxx HD Screen Replacement, Front-Facing Camera: step 5, image 1 of 1
      • On the back of the LCD display, release the yellow front-facing camera ribbon cable by gently lifting upward on the black retaining clip with the spudger.
      Ask FixBot
    2. Motorola RAZR Maxx HD Screen Replacement: step 6, image 1 of 3 Motorola RAZR Maxx HD Screen Replacement: step 6, image 2 of 3 Motorola RAZR Maxx HD Screen Replacement: step 6, image 3 of 3
      • With a Torx T3 screwdriver, unscrew the two 2.0 mm screws on front-facing camera mounting bracket. Then lift to remove it.
      Ask FixBot
    3. Motorola RAZR Maxx HD Screen Replacement: step 7, image 1 of 2 Motorola RAZR Maxx HD Screen Replacement: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to remove the front-facing camera by lifting it from the LCD display frame.
      Ask FixBot
    1. Motorola RAZR Maxx HD Screen Replacement, Earpiece Speaker: step 8, image 1 of 1
      • Insert the spudger between the speaker and retaining clip and gently pry upward to release the earpiece speaker.
      Ask FixBot
    2. Motorola RAZR Maxx HD Screen Replacement: step 9, image 1 of 2 Motorola RAZR Maxx HD Screen Replacement: step 9, image 2 of 2
      • Using a spudger, gently pry up on the lower right edge of the black earpiece speaker ribbon cable, attached to the screen, to release it from the LCD display.
      Ask FixBot
8 other people completed this guide.
Author
with
Enrique
371 Reputation
2 Guides authored
Cal Poly, Team 8-40, Amido Winter 2015 Member of Cal Poly, Team 8-40, Amido Winter 2015
CPSU-AMIDO-W15S8G40
5 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 107
All Time: 3,519
