Motorola RAZR Maxx HD Battery Replacement
    1. Motorola RAZR Maxx HD Battery Replacement, Screen Removal: step 1, image 1 of 2 Motorola RAZR Maxx HD Battery Replacement, Screen Removal: step 1, image 2 of 2
      • Use the Torx T5 Screwdriver to remove two 5.0 mm screws at the bottom of the phone.
      Ask FixBot
    2. Motorola RAZR Maxx HD Battery Replacement: step 2, image 1 of 2 Motorola RAZR Maxx HD Battery Replacement: step 2, image 2 of 2
      • To remove the SIM card, use an unfolded paperclip to press down on the metal plate on the left side of the phone until it pops up.
      Ask FixBot
    3. Motorola RAZR Maxx HD Battery Replacement: step 3, image 1 of 2 Motorola RAZR Maxx HD Battery Replacement: step 3, image 2 of 2
      • Gently push the screen toward the top edge of the phone and tilt the screen to reveal the black flex cables.
      • Do NOT remove the screen all the way or the flex cables will be damaged.
      Ask FixBot
    4. Motorola RAZR Maxx HD Battery Replacement: step 4, image 1 of 2 Motorola RAZR Maxx HD Battery Replacement: step 4, image 2 of 2
      • Release the two black ribbon flex cables by gently pulling up on the connection using the spudger. Then lift the screen to remove.
      • Make sure to remove the flex cables before completely removing the screen.
      • When reassembling, align the white bands on the edge of the screen so that a connection is made.
      Ask FixBot
    1. Motorola RAZR Maxx HD Battery Replacement, Circuit Board: step 5, image 1 of 3 Motorola RAZR Maxx HD Battery Replacement, Circuit Board: step 5, image 2 of 3 Motorola RAZR Maxx HD Battery Replacement, Circuit Board: step 5, image 3 of 3
      • Remove the plastic yellow tape on the battery connector using the spudger.
      • Pry up on the orange connection to release it from the motherboard.
      Ask FixBot
    2. Motorola RAZR Maxx HD Battery Replacement: step 6, image 1 of 1
      • Unscrew all ten 4.0 mm screws on the motherboard using a T5 Torx screwdriver.
      Ask FixBot
    3. Motorola RAZR Maxx HD Battery Replacement: step 7, image 1 of 2 Motorola RAZR Maxx HD Battery Replacement: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers, remove the clear plastic covering on the speaker.
      • Pry open the connection by lifting up on the speaker wire connector.
      Ask FixBot
    4. Motorola RAZR Maxx HD Battery Replacement: step 8, image 1 of 2 Motorola RAZR Maxx HD Battery Replacement: step 8, image 2 of 2
      • Using tweezers, remove the back facing camera cover.
      Ask FixBot
    5. Motorola RAZR Maxx HD Battery Replacement: step 9, image 1 of 2 Motorola RAZR Maxx HD Battery Replacement: step 9, image 2 of 2
      • Using the spudger tool, release the yellow ribbon cable on the headphone jack cover by pushing up on the connection.
      • Remove the cover from the motherboard.
      Ask FixBot
    6. Motorola RAZR Maxx HD Battery Replacement: step 10, image 1 of 1
      • Release the yellow flex cable on the right side of the phone using the spudger by lifting up on the retaining clip.
      Ask FixBot
    7. Motorola RAZR Maxx HD Battery Replacement: step 11, image 1 of 3 Motorola RAZR Maxx HD Battery Replacement: step 11, image 2 of 3 Motorola RAZR Maxx HD Battery Replacement: step 11, image 3 of 3
      • Wedge the spudger between the motherboard and the back case.
      • Work your way around the entire edge of the motherboard to release it and remove it from the back of the phone.
      Ask FixBot
    1. Motorola RAZR Maxx HD Battery Replacement, Battery: step 12, image 1 of 2 Motorola RAZR Maxx HD Battery Replacement, Battery: step 12, image 2 of 2
      • Wedge the spudger tool under the battery to remove it from the back case.
      Ask FixBot
12 other people completed this guide.
Anna Sullivan
880 Reputation
3 Guides authored
Cal Poly, Team 8-40, Amido Winter 2015 Member of Cal Poly, Team 8-40, Amido Winter 2015
CPSU-AMIDO-W15S8G40
5 Members
108 Guides authored
1 Guide Comment
When putting it all back together, is it recommended to replace the pieces of tape to protect/insulate the connectors, or is that not necessary?
FreeMan - Reply Share
Past 24 Hours: 4
Past 7 Days: 30
Past 30 Days: 110
All Time: 6,119
