Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Phone won't turn on
Your phone might not to turn on after repeatedly pressing the turn on button. Some possible explanations are detailed below.
Drained/bad battery
If your phone won't turn on and the battery does not hold a charge, then the battery is dead and needs to be replaced.
Bad display
It is possible that it appears nothing is happening because the display is bad. The screen might have taken in water or it might be cracked. If the display is faulty, it must be replaced. Here is a link to replacing the LCD screen. Motorola Defy LCD Replacement
Faulty motherboard
If all of the other has been checked, the problem most likely lies in the motherboard and must be replaced. If your phone has been in contact with water it means that your motherboard might be damaged. Here is a link to replacing the motherboard. Motorola Defy Motherboard Replacement
Phone not producing sound
You have tried to turn the volume up and down, but cannot hear anything.
Volume is muted
Before tearing the phone apart, check to see that the volume on the phone has not been muted.
Speaker is broken
If you have checked the phone to make sure the volume is not muted and there is still no sound, then the speaker may be broken and must be replaced. Here is a link to replacing the speaker. Motorola Defy Earpiece Speaker Replacement
Phone calls are not connecting
You know a friend is calling you but you are unable to establish a connection.
Poor signal
If calls are not connecting or being dropped, this may be due to being in a poor area for cell phone reception or signal. Often times, one can check the cell phone providers website and see a map of good and bad cell phone reception areas.
Antenna is broken
If, after checking the cell phone services map for good and bad reception areas and the signal and phone calls are still not connecting properly, then the antenna may be broken, and must be replaced. Here is a link to replacing the antenna. Motorola Defy Antenna Replacement
Phones camera does not work
You have tried to use the camera on your phone, but the camera does not seem to be working right.
The display is broken
Before taking apart the phone, make sure that the phones screen is working properly. If you cannot do or see anything on the screen, then the LCD screen is broken and must be replaced.
Broken camera module
If you have checked the above for any errors with the LCD screen, and everything else seems to be working properly with the phone, then it is most likely the camera module itself is broken and must be replaced. Here is a guide to replacing the camera module. Motorola Defy Rear Facing Camera Replacement
Author
with
Morgan Roark
325 Reputation
3 Guides authored
USF Tampa, Team 14-2, Leahy Fall 2014 Member of USF Tampa, Team 14-2, Leahy Fall 2014
USFT-LEAHY-F14S14G2
4 Members
72 Guides authored
1 Comment
help! 1 have 2 mileston 2’s.I cant remember any passwords.the pc i connected with died!i have photos on them i want to keep.tried lots you tube fixes.dont think i have sim cards.can you help me unlock please?
lrrnwingate2 - Reply Share
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 30
All Time: 1,594
