Up to 20% off select tools
Motorola Defy Antenna Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
97
All Time:
1,479
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 25 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will go through the steps of replacing the antenna for the Motorola MB525 starting from the tear down of the phone to replacement of the antenna itself.
    1. Motorola Defy Antenna Replacement, Rear Case: step 1, image 1 of 1
      • Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
      Ask FixBot
    2. Motorola Defy Antenna Replacement: step 2, image 1 of 2 Motorola Defy Antenna Replacement: step 2, image 2 of 2
      • Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
      Ask FixBot
    1. Motorola Defy Antenna Replacement, Battery: step 3, image 1 of 1
      • Use a plastic opening tool to pry the battery out of the phone.
      Ask FixBot
    1. Motorola Defy Antenna Replacement, Antenna: step 4, image 1 of 2 Motorola Defy Antenna Replacement, Antenna: step 4, image 2 of 2
      • Take the metal spudger and pry the black piece, where the sim card goes, off to get to the entire antenna.
      Ask FixBot
    2. Motorola Defy Antenna Replacement: step 5, image 1 of 3 Motorola Defy Antenna Replacement: step 5, image 2 of 3 Motorola Defy Antenna Replacement: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Pry the antenna off using the metal spudger and tweezers and replace with the new one.
      Ask FixBot
Author
with
Morgan Roark
325 Reputation
3 Guides authored
USF Tampa, Team 14-2, Leahy Fall 2014 Member of USF Tampa, Team 14-2, Leahy Fall 2014
USFT-LEAHY-F14S14G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 97
All Time: 1,479
