Up to 20% off select tools
Motorola Defy LCD Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
90
All Time:
1,792
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will go through the steps of replacing the LCD screen for the Motorola MB525 starting from the tear down of the phone to replacement of the LCD screen itself.
    1. Motorola Defy LCD Replacement, Rear Case: step 1, image 1 of 1
      • Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
      Ask FixBot
    2. Motorola Defy LCD Replacement: step 2, image 1 of 2 Motorola Defy LCD Replacement: step 2, image 2 of 2
      • Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
      Ask FixBot
    1. Motorola Defy LCD Replacement, Battery: step 3, image 1 of 1
      • Use a plastic opening tool to pry the battery out of the phone.
      Ask FixBot
    1. Motorola Defy LCD Replacement, Midframe: step 4, image 1 of 1
      • Unscrew the two silver screws located at the top of the back of the phone.
      Ask FixBot
    2. Motorola Defy LCD Replacement: step 5, image 1 of 1
      • Use a plastic opening tool to gently pry the midframe from the rest of the phone.
      Ask FixBot
    1. Motorola Defy LCD Replacement, Motherboard: step 6, image 1 of 2 Motorola Defy LCD Replacement, Motherboard: step 6, image 2 of 2
      • Use metal spudger to pry off the middle yellow flap carefully.
      Ask FixBot
    2. Motorola Defy LCD Replacement: step 7, image 1 of 3 Motorola Defy LCD Replacement: step 7, image 2 of 3 Motorola Defy LCD Replacement: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers again to pry off the second yellow flap carefully.
      Ask FixBot
    3. Motorola Defy LCD Replacement: step 8, image 1 of 1
      • The motherboard is the whole green board. Pry it off carefully with tweezers from the sides and place it aside.
      Ask FixBot
    1. Motorola Defy LCD Replacement, Removing the LCD: step 9, image 1 of 2 Motorola Defy LCD Replacement, Removing the LCD: step 9, image 2 of 2
      • Stick the metal spudger in between the LCD screen and the case of the phone.
      • Remove the LCD screen and replace with a new one.
      Ask FixBot
2 other people completed this guide.
Author
with
Ebrahem AlRayes
183 Reputation
1 Guide authored
USF Tampa, Team 14-2, Leahy Fall 2014 Member of USF Tampa, Team 14-2, Leahy Fall 2014
USFT-LEAHY-F14S14G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 90
All Time: 1,792
