Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
LED Light Does Not Power On
The LED light does not power on when you hold down the trigger.
Battery is Disconnected
If the battery is disconnected, the LED light will not turn on. Check to make sure the battery is correctly attached with our battery replacement guide. Once the battery is connected properly, press the trigger to see if the light illuminates while the drill spins.
The LED Bulb is Dead
A common reason for the LED light to not turn on is because the bulb is dead. Check to make sure the battery is charged and attached first. If the light is still not working, the bulb may be dead, and you can follow the Makita XPH01 LED Light Replacement guide to change it.
Motor is Unresponsive
The motor is unresponsive when you hold down the trigger.
The Battery is Dead
Make sure the battery is charged before operating the drill. It is possible that the drill will not respond if the charge is too low. Once you check to see if the battery is charged and properly connected, press down on the trigger.
Motor Drill Brushes are Worn Out
After constant use of the drill, the motor drill brushes are likely to wear out. Please follow our guide to change the motor drill brushes.
Trigger Switch Not Working
The trigger will not activate the drill.
Safety Lock Engaged
In order to activate the drill, you must push the trigger down. You cannot press the trigger if the safety lock is engaged. Make sure the safety lock is switched to forward or reverse before operating the device.
The Battery is Dead
The drill will not function if the battery is dead or not properly connected. Make sure the battery is charged and connected to the drill.
The Trigger Assembly has Gone Bad
If the trigger switch pushes down but does not engage the motor, your trigger may be bad.
Forward/Reverse Change Lever has Worn Out
It is a possibility that the forward/reverse change lever has worn out and needs to be replaced. This is indicated by cracked plastic on the change lever itself. Please follow our guide to replace the forward/reverse change lever.
Drill Overheating
The drill becomes very hot when using.
Drill Used for Too Long
When using the drill for a long period of time, the drill starts to heat up. Simply let go of the trigger to stop drilling, and let the drill cool down. Make sure the safety lock is engaged for safety purposes. Once cooled down, you can resume drilling again.
Drill Clutch Slipping
The clutch becomes disengaged.
The Slip-Clutch Setting is Not Right
There are numerical values on the clutch that represent the amount of torque the drill can exert on a screw. Depending on the type of screw, you can set the value of the torque. If the clutch slips before a screw is fully drilled in, it means that the torque value is not high enough. Simply rotate the setting to a higher value. If you drill the screw too deeply, you may want to adjust the setting to a lower value.
Clutch Leaf Spring is Worn Out/Missing
If the clutch does not firmly ‘click’ onto the right gear, it is possible that the leaf spring is worn out or simply missing. It is a common occurrence for someone to open the drill and when reassembling they do not put the leaf spring back into its correct place. Please follow our guide to replace the clutch leaf spring.
Eric Herwatt
1,038 Reputation
7 Guides authored
Cal Poly, Team 15-4, Livingston Fall 2016 Member of Cal Poly, Team 15-4, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G4
4 Members
84 Guides authored
19 Comments
It got hot then forward stopped working reverse still works what could the problem be.
Jimbo Lewis - Reply Share
Hi, ive got a Makita XPH07 (DPH451). Its become intermittent and pretty much not working at all. Ive replaced the trigger thinking it was that, but the problem still persists making me think its the brushes, except its a brushless drill. The armature doesnt spin easily turning by hand if its meant to? Not sure.. Do yyou know what the problem could be?
Daniel Anderson - Reply Share
Check the condition of the battery contacts in the base of the drill. They get worn/pitted/carbonised with use and whilst the poor connection is able to supply enough power to light the work LED (very, very little) as soon as you ask for enough juice to turn the motor, the resistance is too great and nothing happens. It is very similar to the effect in a car when the accessories, dash lights etc work but the engine won’t turn over - due to a poor battery connection. A new contact assembly is very cheap and easy to change (UK£10 or so).
martinwinlow - Reply Share
So the drill I have is fairly new, and it began overheating. I let it rest and it started working again. This problem happened again, but this time it won’t start working again. I’ve tried both batteries and it isn’t helping. I checked the brushes and pushed them down to see if they were the issue. The brushes are still almost fully intact but pushing them down did nothing. What should I check next?
Erik Boyd - Reply Share
I put a bit into an extender and now I can’t get the bit out. Is there a trick to it?
kbertrand - Reply Share
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 82
All Time: 35,687
