Makita XPH01 LED Light Replacement
Views: 3.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
98
All Time:
3,496
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show you the necessary steps to locate and replace the LED light. It shows how to remove the battery and the outer casing in order to locate the LED light on the drill.
Tools
    1. Makita XPH01 LED Light Replacement, Battery: step 1, image 1 of 1
      • Hold the drill upright.
      • Place your finger on the white battery-release button.
      Ask FixBot
    2. Makita XPH01 LED Light Replacement: step 2, image 1 of 1
      • Press and hold the white release button located on the front of the battery.
      Ask FixBot
    3. Makita XPH01 LED Light Replacement: step 3, image 1 of 1
      • Slide the battery forward while pressing down on the white battery-release button.
      Ask FixBot
    1. Makita XPH01 LED Light Replacement, Outer Casing: step 4, image 1 of 2 Makita XPH01 LED Light Replacement, Outer Casing: step 4, image 2 of 2
      • Hold the drill upright with the back panel facing you.
      • Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
      Ask FixBot
    2. Makita XPH01 LED Light Replacement: step 5, image 1 of 1
      • Apply slight pressure to the sides of the backplate and pull away from the drill.
      Ask FixBot
    3. Makita XPH01 LED Light Replacement: step 6, image 1 of 2 Makita XPH01 LED Light Replacement: step 6, image 2 of 2
      • Unscrew the nine 18 mm screws from the outer casing using a Phillips PH2 screwdriver.
      Ask FixBot
    4. Makita XPH01 LED Light Replacement: step 7, image 1 of 2 Makita XPH01 LED Light Replacement: step 7, image 2 of 2
      • Apply slight pressure to the sides of the outer casing and pull away from the drill.
      Ask FixBot
    1. Makita XPH01 LED Light Replacement, LED Light: step 8, image 1 of 2 Makita XPH01 LED Light Replacement, LED Light: step 8, image 2 of 2
      • Use the pointed end of a plastic spudger to push the LED out of the drill.
      Ask FixBot
    2. Makita XPH01 LED Light Replacement: step 9, image 1 of 2 Makita XPH01 LED Light Replacement: step 9, image 2 of 2
      • Use the pointed edge of a spudger to pull out the black and white wires located on the left hand side of the drill.
      • Use the pointed edge of a spudger to pull out the plastic connector.
      Ask FixBot
    3. Makita XPH01 LED Light Replacement: step 10, image 1 of 3 Makita XPH01 LED Light Replacement: step 10, image 2 of 3 Makita XPH01 LED Light Replacement: step 10, image 3 of 3
      • Use the flat end of the spudger to push in the clip on the plastic connector.
      • Pull both sides of the plastic connector apart.
      Ask FixBot
    4. Makita XPH01 LED Light Replacement: step 11, image 1 of 3 Makita XPH01 LED Light Replacement: step 11, image 2 of 3 Makita XPH01 LED Light Replacement: step 11, image 3 of 3
      • Pull the silver metal clip on the motor away from the drill.
      Ask FixBot
    5. Makita XPH01 LED Light Replacement: step 12, image 1 of 1
      • Pull the black trigger assembly away from the drill.
      Ask FixBot
    6. Makita XPH01 LED Light Replacement: step 13, image 1 of 2 Makita XPH01 LED Light Replacement: step 13, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to pull out the LED light assembly.
      Ask FixBot
2 other people completed this guide.
Eric Herwatt
1,038 Reputation
7 Guides authored
Cal Poly, Team 15-4, Livingston Fall 2016 Member of Cal Poly, Team 15-4, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G4
4 Members
84 Guides authored
1 Guide Comment
Should I do these steps if my drill is under a warranty?
Richard Williams - Reply Share
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 98
All Time: 3,496
