Up to 20% off select tools
Makita XPH01 Forward/Reverse Switch Replacement
Views: 7.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
35
Past 30 Days:
143
All Time:
7,247
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show you the necessary steps to replace the forward/reverse switch. It shows how to remove the battery and the outer casing, in order to locate the forward/reverse switch on the drill.
    1. Makita XPH01 Forward/Reverse Switch Replacement, Battery: step 1, image 1 of 1
      • Hold the drill upright.
      • Place your finger on the white battery-release button.
      Ask FixBot
    2. Makita XPH01 Forward/Reverse Switch Replacement: step 2, image 1 of 1
      • Press and hold the white release button located on the front of the battery.
      Ask FixBot
    3. Makita XPH01 Forward/Reverse Switch Replacement: step 3, image 1 of 1
      • Slide the battery forward while pressing down on the white battery-release button.
      Ask FixBot
    1. Makita XPH01 Forward/Reverse Switch Replacement, Outer Casing: step 4, image 1 of 2 Makita XPH01 Forward/Reverse Switch Replacement, Outer Casing: step 4, image 2 of 2
      • Hold the drill upright with the back panel facing you.
      • Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
      Ask FixBot
    2. Makita XPH01 Forward/Reverse Switch Replacement: step 5, image 1 of 1
      • Apply slight pressure to the sides of the backplate and pull away from the drill.
      Ask FixBot
    3. Makita XPH01 Forward/Reverse Switch Replacement: step 6, image 1 of 2 Makita XPH01 Forward/Reverse Switch Replacement: step 6, image 2 of 2
      • Unscrew the nine 18 mm screws from the outer casing using a Phillips PH2 screwdriver.
      Ask FixBot
    4. Makita XPH01 Forward/Reverse Switch Replacement: step 7, image 1 of 2 Makita XPH01 Forward/Reverse Switch Replacement: step 7, image 2 of 2
      • Apply slight pressure to the sides of the outer casing and pull away from the drill.
      Ask FixBot
    1. Makita XPH01 Forward/Reverse Switch Replacement, Forward/Reverse Switch: step 8, image 1 of 1
      • Pull the black trigger assembly away from the drill.
      Ask FixBot
    2. Makita XPH01 Forward/Reverse Switch Replacement: step 9, image 1 of 2 Makita XPH01 Forward/Reverse Switch Replacement: step 9, image 2 of 2
      • Grab onto the forward/reverse switch.
      • Gently pull the forward/reverse switch to separate it from the trigger assembly.
      Ask FixBot
4 other people completed this guide.
Author
with
Eric Herwatt
1,038 Reputation
7 Guides authored
Cal Poly, Team 15-4, Livingston Fall 2016 Member of Cal Poly, Team 15-4, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G4
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 35
Past 30 Days: 143
All Time: 7,247
