Powerbook will not turn on
Charge the battery
The battery may not be charged. Plug a power adapter cord into the laptop and connect to an outlet for an extended period of time, allowing the battery to charge.
Battery not properly seated
Make sure the battery is properly seated in the battery compartment.
Resetting the Powerbook
Press the RESET button located on the back panel marked by a circle with a vertical line through it.
Cannot Eject a Floppy Disk
Restart the laptop
Restart the laptop and try ejecting the floppy disk again.
Disk may be stuck
Your disk may be stuck. You may manually eject it by placing the end of a straightened paper clip into the small hole near the opening of the drive, and push firmly until disk is ejected.
Track pad Malfunctioning
Use one finger
Make sure to only use one, clean, dry finger on the trackpad.
Computer may be slow
A program may be busy; wait a few moments and try again.
Restart the laptop
Try to restart the laptop because the track pad might not have registered during start up.
Replacing the track pad
If none of the above solutions work, the track pad may need to be removed and replaced. Follow the instructions of this guide.
The Computer Freezes
Closing programs
Try to close any programs that are running to unfreeze the computer.
Force quitting programs
Force quit the program by pressing the Command, Option and Escape keys on the keyboard. Select the force quit option in the box that appears.
System errors
If the display says system error, try resetting the computer by pressing the reset button on the back of the computer.
Replacing the ram
If the previous suggestions do not work you may need to reset or replace the parameter RAM (PRAM).
Keyboard not Working
Restarting laptop
If the keyboard is not working, try restarting the laptop as the keyboard may not have registered during start up.
Clean the keyboard
Try to clean the keyboard and make sure its not dirty.
Downloading the latest software
Try downloading the latest software for the keyboard on the product website and manually reinstall the drivers.
Replace the keyboard
If none of these work, you may need to remove and/or replace your keyboard. Refer to our guide here on how to disassemble a 5300cs keyboard.
The computer makes weird noises when booting up.
Use disk tools CD
If four tones are heard, start the computer with the Disk Tools CD that came with the computer.
Resetting the RAM
To reset the RAM restart the computer. Immediately after hear the start up tone, simultaneously press down the command, Option, P and R keys. Hold down the keys until the start up tone repeats itself three times, then release them. When the computer shuts down turn it on again, with the RAM reset.
Replacing the RAM
You may need to replace the parameter RAM also known as the RAM.
The charger is not charging the battery.
Charger or outlet may not be working
Try using a different charger or power outlet to make sure that both are in working order.
Battery may need to be replaced
Replace the battery by following this battery guide.
Other helpful sources:
http://homepage.mac.com/micahgartman/web...
Danielle Noce
23 Reputation
0 Guides authored
Cal Poly, Team 6-1, Regan Fall 2011 Member of Cal Poly, Team 6-1, Regan Fall 2011
CPSU-REGAN-F11S6G1
4 Members
72 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 28
All Time: 1,453
