Macintosh Powerbook 5300cs Trackpad Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
104
All Time:
1,755
Comments: 4
4 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
The trackpad is used to move the cursor on the screen. It is located below the keyboard.
Tools
    1. Macintosh Powerbook 5300cs Trackpad Replacement, Battery: step 1, image 1 of 1
      • The battery compartment is located in the front-right side of the laptop.
      Ask FixBot
    2. Macintosh Powerbook 5300cs Trackpad Replacement: step 2, image 1 of 1
      • To insert the battery, gently slide it into the compartment until it clicks in place.
      • To remove, slide the button highlighted in the red rectangle to the right to release the battery and slide it from the compartment.
      Ask FixBot
    1. Macintosh Powerbook 5300cs Trackpad Replacement, Keyboard: step 3, image 1 of 1
      • With the laptop upside down and with the battery removed, use a Torx #9 screw driver to remove the three .84 in. screws shown.
      Ask FixBot
    2. Macintosh Powerbook 5300cs Trackpad Replacement: step 4, image 1 of 2 Macintosh Powerbook 5300cs Trackpad Replacement: step 4, image 2 of 2
      • Carefully pull up on the front of the keyboard to pop it out from the case.
      • Then slide the back out so the keyboard becomes nearly free.
      Ask FixBot
    3. Macintosh Powerbook 5300cs Trackpad Replacement: step 5, image 1 of 3 Macintosh Powerbook 5300cs Trackpad Replacement: step 5, image 2 of 3 Macintosh Powerbook 5300cs Trackpad Replacement: step 5, image 3 of 3
      • Disconnect the ribbon that is connecting the keyboard to the rest of the computer.
      • Pull the keyboard out and repair or replace as needed.
      Ask FixBot
    1. Macintosh Powerbook 5300cs Trackpad Replacement, Trackpad: step 6, image 1 of 3 Macintosh Powerbook 5300cs Trackpad Replacement, Trackpad: step 6, image 2 of 3 Macintosh Powerbook 5300cs Trackpad Replacement, Trackpad: step 6, image 3 of 3
      • Remove the front plastic panel of the laptop by carefully lifting it up and forward.
      • There will be another another ribbon cable connecting the trackpad; use caution when lifting the front panel.
      Ask FixBot
    2. Macintosh Powerbook 5300cs Trackpad Replacement: step 7, image 1 of 1
      • Remove the orange stripped ribbon that connects the trackpad to the device by carefully pulling the ribbon from its connector up and out.
      Ask FixBot
    3. Macintosh Powerbook 5300cs Trackpad Replacement: step 8, image 1 of 2 Macintosh Powerbook 5300cs Trackpad Replacement: step 8, image 2 of 2
      • With a Torx #9 screwdriver, remove the two .20 in. screws circled in red that are holding the trackpad in place. This will disconnect the mouse button.
      • Following this action, disconnect the ribbon highlighted with the red rectangle connecting the trackpad to the laptop.
      • Remove the mouse button by sliding it out from the top of the orange ribbon.
      Ask FixBot
    4. Macintosh Powerbook 5300cs Trackpad Replacement: step 9, image 1 of 1
      • The trackpad can now be removed from the laptop. Adjust the trackpad as needed.
      Ask FixBot
2 other people completed this guide.
Ronan
72 Reputation
4 Guides authored
Cal Poly, Team 6-1, Regan Fall 2011 Member of Cal Poly, Team 6-1, Regan Fall 2011
CPSU-REGAN-F11S6G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 104
All Time: 1,755
