Phone won't turn on
No matter what you do, you can't get your phone to turn on.
Drained Battery
If your phone isn't turning on, then it may have a drained battery. This problem can be addressed by plugging the phone into the charger and leaving the battery to charge for the full 8 hours. You would then hold the power button down for approximately 3-5 seconds until the screen lights up, or an emblem appears.
Bad Display
It is possible that the phone does not appear to be working because the display is bad. If this is the case, you will need to replace the LCD screen by following the installation guide.
Bad Mother Board
If the Mother Board is defective, or becomes sufficiently damaged, then the phone will completely cease to function. If this is the case, one can replace this part by following our guide for installing the Mother Board.
Phone not charging
Your phone will not charge or hold a charge.
Loose Charging Port
If the phone gives no indication that it is charging when the charging cable is connected, then the charging port may be dislodged. You can attempt to reseat the port.
Damaged or Bad Battery
If the battery is only holding charge for a short time, it is sometimes possible that draining the battery fully, and then recharging for the full eight hours while the phone is turned off. If this does nothing to repair the battery, it may be necessary to get a new battery for your phone. In this case, you would simply take the back panel off, take the old battery out and replace it with the new battery (carefully lining up the positive and negative sides), then reattach the back panel. If step-by-step instructions will benefit you, take a look at our battery installation guide.
Phone screen is blank/white
The display is an unchanging grey or white when turned on.
Damaged Screen
The screen is often the first part of the phone to break if the phone is dropped or stepped on. You will know that the screen is damaged by the crack or discoloration of the front or inside LCD. If this is the case, you will need to follow the repair guide for installing a new screen.
Crashed Operating System
You can reset the phone by removing the back panel, disconnecting the battery for at least a minute, and then reconnecting the battery and restarting the phone by holding the power button for 3 to 5 seconds. If this does not work, you may be able to replace the Mother Board (which runs the operating system) by following our guide to install a new Mother Board.
Microphone not working
The person on the other end cannot hear you.
Wet Microphone
It is possible that the microphone is acting up due to recent water damage. If this is the case, you should immediately follow the steps in our battery installation guide to remove the battery and allow the electronics to dry. You may also wish to further disassemble the device to facilitate faster and more complete drying. Once the components are dry, reassemble the phone for use.
Audio Port not working
Your head phones will not plug in, or you cannot hear when they are plugged in.
Dislodged Audio Port
The audio port is connected to the mother board through six points that have been soldered. If one of these connections is broken, the audio port will not work. If this happens, you will need to follow our guide for installing a new audio port.
Blocked Audio Port
The entry to the audio port can become blocked with dirt and grime that will not allow the head phones to fully plug in to the port. If this is the issue, you will often be able to see the particle lodged in the port hole; if you can, use an unfolded paper clip or another sharp object to try and dislodge the particle. If this does not work, you may need to install a new audio port.
Author
with
Kerri Blosch
4 Reputation
0 Guides authored
Cal Poly, Team 7-33, Maness Spring 2012 Member of Cal Poly, Team 7-33, Maness Spring 2012
CPSU-MANESS-S12S7G33
4 Members
60 Guides authored
4 Comments
Sell on my LG phone my screen is a grayish white how do I fix it
Kim Pearson - Reply Share
On my LG phone my screen is a great white color how do I fix it
My LG phone had been untouched for about 4-5 years. I plugged it in today and the verizon logo just keeps appearing and disappearing. I have tried to reset the battery, and nothing is seeming to work. How can I fix this?
Lillian Godwin - Reply Share
Contact strip for Hinged connecting ports torn?
joesaxon2011 - Reply Share
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 15
All Time: 10,081
