LG VX5500 Mother Board Replacement
  1. LG VX5500 Mother Board Replacement, Battery: step 1, image 1 of 3 LG VX5500 Mother Board Replacement, Battery: step 1, image 2 of 3 LG VX5500 Mother Board Replacement, Battery: step 1, image 3 of 3
    • Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery.
    • Our device did not come with a battery cover so it is not shown here.
    • Remove the battery using your finger to pry it out of the battery housing.
    Ask FixBot
  2. LG VX5500 Mother Board Replacement, Mother Board: step 2, image 1 of 2 LG VX5500 Mother Board Replacement, Mother Board: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the (2) rubber screw covers located near the hinge of the phone using tweezers or a thumb tack.
    • Unscrew the (4) 3.6mm screws using a #00 Phillip's head screw driver.
    Ask FixBot
  3. LG VX5500 Mother Board Replacement: step 3, image 1 of 3 LG VX5500 Mother Board Replacement: step 3, image 2 of 3 LG VX5500 Mother Board Replacement: step 3, image 3 of 3
    • Carefully pry off the phone's backing using a plastic opening tool.
    • Slip the tool into the crack between the keypad (front panel) and the back panel.
    • Slide the tool along the sides of the phone to detach the tabs holding the backing on.
    Ask FixBot
  4. LG VX5500 Mother Board Replacement: step 4, image 1 of 2 LG VX5500 Mother Board Replacement: step 4, image 2 of 2
    • Peel back the sticker with tweezers and hold it back with your finger.
    • Use the tweezers to lift the display adapter off the logic board.
    Ask FixBot
  5. LG VX5500 Mother Board Replacement: step 5, image 1 of 2 LG VX5500 Mother Board Replacement: step 5, image 2 of 2
    • Lift the mother board out of the phone casing.
    • The keyboard can be easily removed once the mother board is out of the phone.
    Ask FixBot
2 other people completed this guide.
Henry
181 Reputation
3 Guides authored
Cal Poly, Team 7-33, Maness Spring 2012 Member of Cal Poly, Team 7-33, Maness Spring 2012
CPSU-MANESS-S12S7G33
4 Members
15 Guides authored
2 Guide Comments
You guys are great!
Kurt Beske - Reply Share
So what do you do with the mother board then?
Erik Sodders - Reply Share
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 40
All Time: 2,540
