Up to 20% off select tools
LG VX5500 Screen Replacement
Views: 4.7K
View statistics:
Past 24 Hours:
5
Past 7 Days:
18
Past 30 Days:
89
All Time:
4,677
Comments: 2
2 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide gives step-by-step instructions on how to remove the Primary LCD in the LG VX5500 cell phone. To complete the task you will need a #00 Phillip's head screwdriver and prying tool.
    1. LG VX5500 Screen Replacement, Battery: step 1, image 1 of 3 LG VX5500 Screen Replacement, Battery: step 1, image 2 of 3 LG VX5500 Screen Replacement, Battery: step 1, image 3 of 3
      • Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery.
      • Our device did not come with a battery cover so it is not shown here.
      • Remove the battery using your finger to pry it out of the battery housing.
      Ask FixBot
    1. LG VX5500 Screen Replacement, Screen: step 2, image 1 of 2 LG VX5500 Screen Replacement, Screen: step 2, image 2 of 2
      • Carefully pry off the black plastic screen cover using the iSesamo tool or another thin, flat tool.
      • The screen cover is adhered to the phone and may take some effort to pry off. If it is too difficult to remove, heat the screen with a hair dryer on low for 30 seconds to soften the adhesive.
      Ask FixBot
    2. LG VX5500 Screen Replacement: step 3, image 1 of 2 LG VX5500 Screen Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Unscrew the (4) 3.6mm screws near each corner of the phone's display panel by using a #00 Phillips head screwdriver.
      • The bottom two screws may have small rubber covers that you can remove using tweezers.
      Ask FixBot
    3. LG VX5500 Screen Replacement: step 4, image 1 of 3 LG VX5500 Screen Replacement: step 4, image 2 of 3 LG VX5500 Screen Replacement: step 4, image 3 of 3
      • Pry off the front panel of the phone using a Plastic Opening Tool.
      • Push the tool into the crack along the side of the phone.
      • Slide the tool along the crack to detach the tabs holding the backing on the phone.
      Ask FixBot
    4. LG VX5500 Screen Replacement: step 5, image 1 of 2 LG VX5500 Screen Replacement: step 5, image 2 of 2
      • Use the tweezers to lift the display adapter off the screen component.
      Ask FixBot
    5. LG VX5500 Screen Replacement: step 6, image 1 of 2 LG VX5500 Screen Replacement: step 6, image 2 of 2
      • Using tweezers remove the speaker from its casing.
      • The speaker is adhered to the phone casing so it will take a small amount of force to remove it.
      Ask FixBot
    6. LG VX5500 Screen Replacement: step 7, image 1 of 2 LG VX5500 Screen Replacement: step 7, image 2 of 2
      • Remove the earpiece by lifting it out of the phone casing using tweezers.
      • The earpiece is adhered to the phone casing so it will take a small amount of force to remove it.
      Ask FixBot
    7. LG VX5500 Screen Replacement: step 8, image 1 of 2 LG VX5500 Screen Replacement: step 8, image 2 of 2
      • Remove the vibration motor by lifting it out of the phone casing using tweezers.
      • The motor is adhered to the phone casing so it will take a small amount of force to remove it.
      Ask FixBot
    8. LG VX5500 Screen Replacement: step 9, image 1 of 1
      • Lift the screen components out of the phone.
      Ask FixBot
3 other people completed this guide.
Author
with
Henry
181 Reputation
3 Guides authored
Cal Poly, Team 7-33, Maness Spring 2012 Member of Cal Poly, Team 7-33, Maness Spring 2012
CPSU-MANESS-S12S7G33
4 Members
60 Guides authored
2 Guide Comments
I have it apart know need to learn to solder!
Andy Fowler - Reply Share
where can i purchase a replacement screen?
kalea dean - Reply Share
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 89
All Time: 4,677
