Phone won't turn on
When you push the power key, the phone won't power on.
Bad battery
Remove and then reinsert the battery and try to turn it on again. If that doesn't work, then plug the phone into the charger and try to turn it on. If the phone still doesn't turn on, the battery may be faulty and should be replaced.
No sound comes from the phone
You cannot hear anything when placing a call, no one can hear you when you place a call, or the speakerphone doesn't project sound.
Broken earpiece
If there is no sound from the phone's ear speaker, then either the solder contact is broken or the ear speaker itself has failed. If re-soldering the connection doesn't help then the ear speaker will likely have to be replaced.
Broken microphone
If you cannot be heard through the phone when placing a call, then either the microphone's solder connection is broken or the microphone is faulty. If re-soldering the microphone doesn't help then it may need to be replaced.
Screen wont work
The phone functions but the LCD display remains black.
Bad connection
The connection between the screen and the circuit board may be loose. Be sure that the connection between the screen and the circuit board is firmly in place.
Damaged Screen
If the screen remains black after the connection is in place then the screen may be damaged and will likely have to be replaced.
Keypad won't work
The phone doesn't respond to input from the keypad.
Foreign object under the keypad
If there is a foreign object stuck under the keypad that blacks one or more of the buttons from making contact with the electrical switch underneath then the keypad will need to be disassembled so that the object can be removed.
Misaligned keypad
If one or more of the buttons appear to be sunk in or sticking out too far then they are most likely misaligned with the electrical switches underneath. Many times this can be solved simply by pushing or pulling the buttons back into place. If that doesn't work then disassemble then reassemble the keypad.
Author
with
Johnny Inlow
19 Reputation
3 Guides authored
Cal Poly, Team 27-91, Amido Spring 2010 Member of Cal Poly, Team 27-91, Amido Spring 2010
CPSU-AMIDO-S10S27G91
5 Members
72 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 1,502
