Up to 20% off select tools
LG TP 1100 Keypad Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
22
All Time:
1,936
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Mismatched Prerequisites
This guide does not have a proper prerequisite guide. Help match it to its ideal partner by finding it or writing one!
Tools
Introduction
Go to step 1 ↓
If you're having difficulty inputting numbers into your LG TP 1100 phone, this guide will show you how to replace the keypad. The keypad of this phone allows the input of numbers to your device by pressing the desired button.
If the phone won't power on no matter what button is pressed, it's most likely an issue with the battery rather than the keypad, and the battery should either be removed and reinserted or replaced.
With time, pressing a specific button may not enter the desired number. This could be due to an alignment issue or foreign object trapped beneath the keypad, in which the device should be disassembled to rectify the issue. If the keypad still doesn't work, this means it has to be replaced.
Before beginning the steps provided in this guide, power down the device completely and make sure to disconnect it from any external power source.
    1. LG TP 1100 Keypad Replacement, Keypad: step 1, image 1 of 1
      • Unscrew the antenna.
      Ask FixBot
    2. LG TP 1100 Keypad Replacement: step 2, image 1 of 1
      • Pull the antenna from the socket.
      Ask FixBot
    3. LG TP 1100 Keypad Replacement: step 3, image 1 of 1
      • Turn the phone over to access the back.
      Ask FixBot
    4. LG TP 1100 Keypad Replacement: step 4, image 1 of 1
      • Pull up the tab on the top of the phone.
      Ask FixBot
    5. LG TP 1100 Keypad Replacement: step 5, image 1 of 1
      • Remove the battery.
      Ask FixBot
    6. LG TP 1100 Keypad Replacement: step 6, image 1 of 1
      • Unscrew the four screws behind the battery with a screwdriver.
      Ask FixBot
    7. LG TP 1100 Keypad Replacement: step 7, image 1 of 2 LG TP 1100 Keypad Replacement: step 7, image 2 of 2
      • Pull off the back cover.
      • Do not separate the covers.
      • Do not rip the tape connecting the two covers.
      Ask FixBot
    8. LG TP 1100 Keypad Replacement: step 8, image 1 of 1
      • Remove the back cover.
      Ask FixBot
    9. LG TP 1100 Keypad Replacement: step 9, image 1 of 2 LG TP 1100 Keypad Replacement: step 9, image 2 of 2
      • Pry the circuit board from the front cover.
      • Do not let number pad fall out.
      Ask FixBot
    10. LG TP 1100 Keypad Replacement: step 10, image 1 of 1
      • Remove the number pad.
      Ask FixBot
    11. LG TP 1100 Keypad Replacement: step 11, image 1 of 1
      • Remove the navigation keys.
      Ask FixBot
Author
with
Johnny Inlow
19 Reputation
3 Guides authored
Cal Poly, Team 27-91, Amido Spring 2010 Member of Cal Poly, Team 27-91, Amido Spring 2010
CPSU-AMIDO-S10S27G91
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 22
All Time: 1,936
