Up to 20% off select tools
LG TP 1100 Microphone Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
Past 7 Days:
4
Past 30 Days:
22
All Time:
1,756
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 - 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide provides instructions for replacing the microphone on the LG TP 1100 flip phone.
    1. LG TP 1100 Microphone Replacement, Microphone: step 1, image 1 of 1
      • Hold antenna between your fingers and unscrew in a counterclockwise direction.
      Ask FixBot
    2. LG TP 1100 Microphone Replacement: step 2, image 1 of 1
      • You will remove antenna by pulling it in an upward motion away from the socket.
      Ask FixBot
    3. LG TP 1100 Microphone Replacement: step 3, image 1 of 1
      • Turn phone so that the back is facing you.
      Ask FixBot
    4. LG TP 1100 Microphone Replacement: step 4, image 1 of 1
      • Use your thumb to pull the tab in an upward motion to release the battery.
      Ask FixBot
    5. LG TP 1100 Microphone Replacement: step 5, image 1 of 1
      • Hold phone securely in one hand and pull the battery away from the phone with your other hand.
      Ask FixBot
    6. LG TP 1100 Microphone Replacement: step 6, image 1 of 1
      • Use your screwdriver to unscrew the four screws from the back plate.
      Ask FixBot
    7. LG TP 1100 Microphone Replacement: step 7, image 1 of 1
      • Turn phone to the side as indicated in the picture.
      Ask FixBot
    8. LG TP 1100 Microphone Replacement: step 8, image 1 of 1
      • Remove the back cover that you just unscrewed and set aside.
      Ask FixBot
    9. LG TP 1100 Microphone Replacement: step 9, image 1 of 1
      • Open the remaining parts like a book but do not separate the two pieces.
      • Do not tear the tape connecting the two pieces.
      Ask FixBot
    10. LG TP 1100 Microphone Replacement: step 10, image 1 of 2 LG TP 1100 Microphone Replacement: step 10, image 2 of 2
      • Rotate the phone so that the circuit board is in the palm of your hand and the part connected with tape hangs behind.
      • Use your opening tool to pry the circuit board from the front cover. Do not let the number pad to fall out.
      Ask FixBot
    11. LG TP 1100 Microphone Replacement: step 11, image 1 of 1
      • To remove the microphone, insert your opening tool under microphone and push upward to pry microphone away from the front cover.
      Ask FixBot
Author
with
Johnny Inlow
19 Reputation
3 Guides authored
Cal Poly, Team 27-91, Amido Spring 2010 Member of Cal Poly, Team 27-91, Amido Spring 2010
CPSU-AMIDO-S10S27G91
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 22
All Time: 1,756
