Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Phone won't turn on
Phone is unresponsive and won't turn on.
Assure that the battery is properly inserted
Make sure that the battery is properly placed inside of the phone.
Phone battery is dead
Try charging your phone but be sure that the charger is connected to the phone and wall outlet correctly.
Bad charging cord
Inspect your charger for any kinks or cracks in the cord's coating that would prevent it from charging.
Bad battery
In this case replace your bad battery with a new one.
Battery dying quickly
Phone has unusually short battery life.
Too many applications left open
Make sure all applications that aren't in use are closed to save battery life.
Power saver mode turned off
Go into settings and turn on power saver mode. This should help save battery power.
Bad battery
Replace the phone's battery.
Microphone not picking up audio
When making calls, the person you are talking to cannot hear you.
Phone is muted
Make sure the phone is not muted when making calls.
Bad speaker
Replace the phone's speaker.
Touch screen not working
Digitizer is not registering touch on the phone's touchscreen.
Restart phone
Try restarting your phone by holding down the power button until it shuts off and then turning it back on.
Bad motherboard
Replace the phone's motherboard.
Shattered screen
The screen on the phone appears to be shattered or cracked.
Broken screen
In this case, you will need to replace the phone's screen.
Author
with
Daniela Allbright
642 Reputation
3 Guides authored
USF Tampa, Team 14-1, Leahy Fall 2014 Member of USF Tampa, Team 14-1, Leahy Fall 2014
USFT-LEAHY-F14S14G1
3 Members
60 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 22
All Time: 2,661
