LG Motion 4G MS770 Motherboard Replacement
Views: 2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
25
Past 30 Days:
90
All Time:
1,961
Comments: 0
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If phone will not turn on or has system errors and the troubleshooting did not help then replace the broken motherboard with a new one.
Parts
Tools
    1. LG Motion 4G MS770 Motherboard Replacement, Remove the phone's back cover.: step 1, image 1 of 1
      • Use a plastic opening tool to remove the back cover.
      Ask FixBot
    2. LG Motion 4G MS770 Motherboard Replacement, Remove the battery.: step 2, image 1 of 1
      • Use a plastic opening tool to remove the battery, lifting from the bottom right corner.
      Ask FixBot
    1. LG Motion 4G MS770 Motherboard Replacement, Remove screws.: step 3, image 1 of 1
      • Use a Phillips #00 Screwdriver to remove all eight 4mm screws.
      Ask FixBot
    2. LG Motion 4G MS770 Motherboard Replacement: step 4, image 1 of 2 LG Motion 4G MS770 Motherboard Replacement: step 4, image 2 of 2
      • Use a plastic opening tool to remove the back trim by working around all of the edges.
      Ask FixBot
    3. LG Motion 4G MS770 Motherboard Replacement: step 5, image 1 of 2 LG Motion 4G MS770 Motherboard Replacement: step 5, image 2 of 2
      • Remove the volume buttons from the side.
      Ask FixBot
    1. LG Motion 4G MS770 Motherboard Replacement, Speaker: step 6, image 1 of 2 LG Motion 4G MS770 Motherboard Replacement, Speaker: step 6, image 2 of 2
      • Use a plastic opening tool to lift the speaker off by prying under the silver square as shown.
      • Note: There is a small tab underneath the speaker that will be lifted off when the speaker is removed.
      Ask FixBot
    1. LG Motion 4G MS770 Motherboard Replacement, Rear Facing Camera: step 7, image 1 of 1
      • Pry slightly underneath the tab attached to the camera until it pops off.
      Ask FixBot
    2. LG Motion 4G MS770 Motherboard Replacement: step 8, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to remove the camera, you will need to use some force as it is glued on.
      Ask FixBot
    1. LG Motion 4G MS770 Motherboard Replacement, Motherboard: step 9, image 1 of 1
      • Pry off the circled tabs using a plastic opening tool to release the motherboard.
      Ask FixBot
    2. LG Motion 4G MS770 Motherboard Replacement: step 10, image 1 of 1
      • Lift the motherboard off of the phone. It should come right out.
      Ask FixBot
7 other people completed this guide.
Zarna Patel
320 Reputation
2 Guides authored
USF Tampa, Team 14-1, Leahy Fall 2014 Member of USF Tampa, Team 14-1, Leahy Fall 2014
USFT-LEAHY-F14S14G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 90
All Time: 1,961
