LG Motion 4G MS770 Speaker Replacement
  1. LG Motion 4G MS770 Speaker Replacement, Remove the phone's back cover.: step 1, image 1 of 1
    • Use a plastic opening tool to remove the back cover.
  2. LG Motion 4G MS770 Speaker Replacement, Remove the battery.: step 2, image 1 of 1
    • Use a plastic opening tool to remove the battery, lifting from the bottom right corner.
  3. LG Motion 4G MS770 Speaker Replacement, Remove screws.: step 3, image 1 of 1
    • Use a Phillips #00 Screwdriver to remove all eight 4mm screws.
  4. LG Motion 4G MS770 Speaker Replacement: step 4, image 1 of 2 LG Motion 4G MS770 Speaker Replacement: step 4, image 2 of 2
    • Use a plastic opening tool to remove the back trim by working around all of the edges.
  5. LG Motion 4G MS770 Speaker Replacement: step 5, image 1 of 2 LG Motion 4G MS770 Speaker Replacement: step 5, image 2 of 2
    • Remove the volume buttons from the side.
  6. LG Motion 4G MS770 Speaker Replacement, Speaker: step 6, image 1 of 2 LG Motion 4G MS770 Speaker Replacement, Speaker: step 6, image 2 of 2
    • Use a plastic opening tool to lift the speaker off by prying under the silver square as shown.
    • Note: There is a small tab underneath the speaker that will be lifted off when the speaker is removed.
Daniela Allbright
642 Reputation
3 Guides authored
USF Tampa, Team 14-1, Leahy Fall 2014 Member of USF Tampa, Team 14-1, Leahy Fall 2014
USFT-LEAHY-F14S14G1
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 56
All Time: 457
