Microlight is dim/does not turn on
You have pushed it on but the light is dim or remains off
Burnt Bulb
Open up the microlight. If the bulb is black then it is burned out and needs to be replaced with a new one.
Dead Battery
If the microlight won't turn on and it has not been used recently, your battery may have run out. Simply replace the batteries and test the device. If the device turns on then the problem was a bad or dead battery.
Damaged Microchip
If the microlight has sustained any trauma and features are not accessible, the microchip within the casing may be damaged and should be changed.
Unmatched Polarity
The light bulb may not be matching the polarity with the logic board. Simply removing the light bulb and switching the ends in the input will fix this problem.
The microlight turns off randomly
You are able to turn on the light but it fails to remain on
Turns off at four minutes
If the light is on the first setting, the chip is programmed to shut down automatically to sustain battery life. If this occurs on the second or third mode, then there may be an issue with the battery.
Light is intermittent
The batteries may have a loose connection with the contact spring. A possible solution is to bend the contact spring slightly so that the spring connects with the battery while in the case. If the contact is not the problem the light bulb may be burnt. Replace the light bulb.
Can’t access the four settings
You can turn on the light but it shuts off immediately after releasing the trigger
Factory setting still enabled
If the light only stays on as pressure is applied, then the microlight is still in factory signal mode. Holding down the button for 15 seconds will remove the factory setting and enable the user to access the high, low, strobe, and signal settings.
Author
with
Vincent
130 Reputation
0 Guides authored
CSU Fullerton, Team 2-1, Bruce Fall 2014 Member of CSU Fullerton, Team 2-1, Bruce Fall 2014
CSUF-BRUCE-F14S2G1
3 Members
36 Guides authored
17 Comments
Just installed 2 new batteries -
Pressing the 'on' button, it lights up just fine,
but when you let go of the 'on' button,
it goes off!
i.e., it WON'T STAY ON!
Any and ALL Suggestions to correct this situation will be Greatly Appreciated.
Thank you VERY Much!
rjk4@sbcglobal.net
Richard (916) 961-5966
Richard Kirkham - Reply Share
Light will not stay on after replacing batteries and 'Holding Down button' for 15+ seconds...
I just did the exact same thing! Click and hold the button on for 30 seconds, and it should go off, then work. But I had to do it twice.
laurieholloway1313 - Reply Share
Wish they would edit this entry to say the release of the trigger will happen when the light turns off. Thanks for letting me know, it worked!
merelunacy - Reply Share
Thank you very much! I changed the dead batteries in my "bug lit" and it would not stay on. The 15 sec. reset worked great!
Scott Newbry - Reply Share
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 58
All Time: 11,868
