Nite Ize Inova Microlight Casing Replacement
    1. Nite Ize Inova Microlight Casing Replacement, Case Removal: step 1, image 1 of 2 Nite Ize Inova Microlight Casing Replacement, Case Removal: step 1, image 2 of 2
      • Insert the plastic opening tool into the seam of the device.
      Ask FixBot
    2. Nite Ize Inova Microlight Casing Replacement, Battery Removal: step 2, image 1 of 3 Nite Ize Inova Microlight Casing Replacement, Battery Removal: step 2, image 2 of 3 Nite Ize Inova Microlight Casing Replacement, Battery Removal: step 2, image 3 of 3
      • Squeeze the top battery using a tweezer and pull the battery away from the light bulb.
      • Repeat this step for the bottom remaining battery.
      • Do not pull up on the battery as this will bend the metal contact.
      Ask FixBot
    1. Nite Ize Inova Microlight Casing Replacement, LED Light Removal: step 3, image 1 of 3 Nite Ize Inova Microlight Casing Replacement, LED Light Removal: step 3, image 2 of 3 Nite Ize Inova Microlight Casing Replacement, LED Light Removal: step 3, image 3 of 3
      • Place the plastic opening tool below the LED lamp and push away from the device until you hear a click.
      • Continue to remove the LED lamp the with your fingers.
      Ask FixBot
    2. Nite Ize Inova Microlight Casing Replacement, Logic Board Removal: step 4, image 1 of 1
      • Place the plastic opening tool behind the logic board and bend away from the casing
      Ask FixBot
    3. Nite Ize Inova Microlight Casing Replacement, Logic Board Removal: step 5, image 1 of 1
      • The logic board will pop out with ease.
      Ask FixBot
Jennifer Tabadero
526 Reputation
3 Guides authored
CSU Fullerton, Team 2-1, Bruce Fall 2014 Member of CSU Fullerton, Team 2-1, Bruce Fall 2014
CSUF-BRUCE-F14S2G1
3 Members
36 Guides authored
1 Guide Comment
Great Job! found this one night while looking at my little blue light. Great tools, photos. +30
4-16-2017
F3ND1MUS - Reply Share
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 35
All Time: 1,268
