Nite Ize Inova Microlight Battery Replacement
Views: 7.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
23
Past 30 Days:
112
All Time:
7,189
Comments: 1
1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Use this guide to replace the batteries of a microlight.
Parts
Tools
    1. Nite Ize Inova Microlight Battery Replacement, Case Removal: step 1, image 1 of 2 Nite Ize Inova Microlight Battery Replacement, Case Removal: step 1, image 2 of 2
      • Insert the plastic opening tool into the seam of the device.
      Ask FixBot
    2. Nite Ize Inova Microlight Battery Replacement, Battery Removal: step 2, image 1 of 3 Nite Ize Inova Microlight Battery Replacement, Battery Removal: step 2, image 2 of 3 Nite Ize Inova Microlight Battery Replacement, Battery Removal: step 2, image 3 of 3
      • Squeeze the top battery using a tweezer and pull the battery away from the light bulb.
      • Repeat this step for the bottom remaining battery.
      • Do not pull up on the battery as this will bend the metal contact.
      Ask FixBot
4 other people completed this guide.
Jennifer Tabadero
526 Reputation
3 Guides authored
CSU Fullerton, Team 2-1, Bruce Fall 2014 Member of CSU Fullerton, Team 2-1, Bruce Fall 2014
CSUF-BRUCE-F14S2G1
3 Members
36 Guides authored
1 Guide Comment
There is another Inova flashlight design that involves removing two Phillips type screw heads that are VERY TINY. I am able to unscrew one, but not the other, so am stuck and unable to replace the batteries.
Chrystin - Reply Share
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 112
All Time: 7,189
