Keyboard will not take any inputs
The keyboard is unresponsive when its keys are pressed down.
Loose USB-C cable connection
Make sure that the USB-C cable is properly plugged into the keyboard as well as the computer. If the keyboard is still unresponsive, try using a different USB cable. Any male USB-C to male USB-A will work. If the keyboard is now functioning, then the stock cable is no longer working.
Faulty USB-A port on connected device
Try plugging the keyboard cable into a different USB port on your computer. If this fixes the issue, the original USB port is most likely not working.
If no USB ports seem to be working, try restarting your computer and ensuring your chosen keyboard and language settings are set up properly.
Key switch failure
If only a few keys are unresponsive, while the remaining keys are functioning correctly, the underlying key switches corresponding towards the broken keys may need to be replaced. Consult the HyperX Alloy Origins Key Switch Replacement Guide for more information; in the event of key switch replacement, the keyboard backplate and toggle indicator tab may need to be removed as well.
Keyboard legs are not standing up
The keyboard legs fail to remain standing up on their own.
Legs not on the same settings
Ensure that both the right and left legs are set to same height, which helps the keyboard to remain stable.
Legs have partially fallen out
Ensure that the legs are completely attached to the keyboard case. The legs will snap right into the case, being held in by an axel. If this axel breaks, then the legs need to be replaced. Consult the HyperX Alloy Origins Legs Replacement Guide for more information. Replacement legs can be found both on the manufacturer’s website and on third party websites like Etsy.
LED lights will not turn on
The keyboard takes inputs normally while plugged in, but the LED lights will not turn on.
Software settings
Check the LED settings in the HyperX NGENUITY software to ensure that the LED's are turned on.
Factory reset
Try resetting the keyboard by holding the LEFT ALT, SPACE, and FN keys down simultaneously for five seconds.
Keyboard needs to be updated
In some cases, the keyboard may need to be updated. To do this, go the manufacturer's website and download the specific drivers associated with the HyperX Alloy Origins keyboard.
LED light failure
In the event of complete LED light failure, the LEDs themselves may have to be replaced. Consult the HyperX Alloy Origins Key Switch LED Replacement Guide for more information.
Keyboard sends random inputs
The keyboard is sending inputs without having pressed the keys.
Sticky keys
Some keys may be stuck and may have to be cleaned. Use a keycap remover to remove the cap by slotting it on the side of the desired keycap and pulling up. Once removed, clean the keycap with an alcohol-based cleaning wipe, and use compressed air to clean the area surrounding the key switch, be sure to remove all debris that may be stuck inside the key switch. After cleaning. Plug the keyboard back into the PC. If this does not work, reset the keyboard settings.
Keyboard keeps sliding on table
The keyboard is slippery and moves during normal use.
Clean the keyboard
Ensure there is nothing between the rubber feet and the desk that might cause the keyboard to slide. This includes debris like dust or hair that may have found its way under the keyboard. Clean the rubber with an alcohol-based wipe and allow it to dry. If this fails, install new rubber feet.
Can't press multiple keys at once
 Keyboard can only perform one input at once.
Keyboard is in gaming mode
If you are trying to use keyboard commands with the Windows Key, ensure that the keyboard is not set to gaming mode. Press FN + F12 in order to toggle between modes.
N-key rollover isn't on
If trying to press more that 6 keys at once, ensure that N-Key rollover is activated by pressing FN + DEL. To return to 6 Keys or less, press FN + Insert.
Author
with
Mario Ricci
294 Reputation
2 Guides authored
UMass Dartmouth, Team 5-2, Sinclaire Fall 2022 Member of UMass Dartmouth, Team 5-2, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S5G2
5 Members
72 Guides authored
23 Comments
On the HyperX Alloy Core RGB keyboard, how do you get the all white lighting to stop fading in and out and just stay on White?
Samantha Myers - Reply Share
Fixed. Go to Windows Settings > Personalization > Dynamic Lighting > toggle off “Use dynamic lighting on my devices.” It took me way too long to figure it out. There are tons of forums about this same HyperX issue, and not even they know the answer. I hope this helps.
Nicolás Parra - Reply Share
YES my question exactly Samantha - any joy ?
Tom Gowing - Reply Share
El software de hyperex no reconoce mi teclado.
Germán Corts - Reply Share
buenas tardes, tengo un problema y es que mi teclado alloy fps 60% no reacciona a las flechas der izq arriba abajo, derrepende dejaron de funcionar igual que los modos de camio de color rapido
francisco marroquin - Reply Share
Past 24 Hours: 16
Past 7 Days: 92
Past 30 Days: 460
All Time: 54,493
