HyperX Alloy Origins Key Switch Replacement
Views: 37K
View statistics:
Past 24 Hours:
16
Past 7 Days:
130
Past 30 Days:
567
All Time:
36,966
Comments: 8
1 comment on steps, 7 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 45 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
This guide will show how to replace the mechanical key switches from your HyperX Alloy Origins mechanical keyboard (serial number HX-KB6RDX and its variants).
The stock key switches on the HyperX Alloy Origins are custom HyperX switches. However, they can be replaced with any number of other MX-type switches. Replacing a key switch on the HyperX Alloy Origins may be a quite difficult task for some people, as it requires the use of a soldering iron. However, a new key switch may be able to save a what was previously a broken keyboard.
Before you begin, ensure that the key you want to replace is entirely broken before resorting to such drastic measures. Unplug and reconnect the keyboard, reset the keyboard through the NGENUITY software, and ensure that nothing is preventing the key from being pressed. If none of these methods are working, proceed with the switch removal by first unplugging the keyboard and bringing it to a well lit area. Ground yourself before beginning replacement.
Usage of a desoldering iron or a desoldering pump (alongside a normal soldering iron) is strongly recommended. The HyperX key switches contain pins which make it difficult to wick away solder. This guide uses a sole soldering iron for demonstration purposes only.
Tools
    1. HyperX Alloy Origins Key Switch Replacement, Toggle Indicator Tab: step 1, image 1 of 1
      • Locate the toggle indicator tab on the top right corner of the keyboard.
      Ask FixBot
    2. HyperX Alloy Origins Key Switch Replacement: step 2, image 1 of 2 HyperX Alloy Origins Key Switch Replacement: step 2, image 2 of 2
      • Insert the metal spudger or some other separating instrument into the right crevasse between the tab and the keyboard.
      • Lift up gently on the tab, while holding the left side of the tab down.
      • The tab can spring upwards upon removal. Eye protection is recommended during this step.
      Ask FixBot
    1. HyperX Alloy Origins Key Switch Replacement, Backplate: step 3, image 1 of 2 HyperX Alloy Origins Key Switch Replacement, Backplate: step 3, image 2 of 2
      • Flip the keyboard over so that the backplate is facing you.
      Ask FixBot
    2. HyperX Alloy Origins Key Switch Replacement: step 4, image 1 of 3 HyperX Alloy Origins Key Switch Replacement: step 4, image 2 of 3 HyperX Alloy Origins Key Switch Replacement: step 4, image 3 of 3
      • Remove the rubber feet on the four corners of the backplate.
      • When reassembling, use an adhesive to reattach the feet. A silicone rubber adhesive is recommended.
      Ask FixBot
    3. HyperX Alloy Origins Key Switch Replacement: step 5, image 1 of 3 HyperX Alloy Origins Key Switch Replacement: step 5, image 2 of 3 HyperX Alloy Origins Key Switch Replacement: step 5, image 3 of 3
      • Remove the specified keycaps as depicted in the image.
      Ask FixBot
    4. HyperX Alloy Origins Key Switch Replacement: step 6, image 1 of 3 HyperX Alloy Origins Key Switch Replacement: step 6, image 2 of 3 HyperX Alloy Origins Key Switch Replacement: step 6, image 3 of 3
      • Remove all Philips #0 screws from the new openings created after removing the rubber feet and plastic tab.
      Ask FixBot
    5. HyperX Alloy Origins Key Switch Replacement: step 7, image 1 of 3 HyperX Alloy Origins Key Switch Replacement: step 7, image 2 of 3 HyperX Alloy Origins Key Switch Replacement: step 7, image 3 of 3
      • Separate the backplate from the keyboard using your hands.
      Ask FixBot
    1. HyperX Alloy Origins Key Switch Replacement, Key Switch: step 8, image 1 of 3 HyperX Alloy Origins Key Switch Replacement, Key Switch: step 8, image 2 of 3 HyperX Alloy Origins Key Switch Replacement, Key Switch: step 8, image 3 of 3
      • Identify the key switch to be replaced.
      • Remove its keycap by carefully prying it off of the keyboard with your fingers.
      Ask FixBot
    2. HyperX Alloy Origins Key Switch Replacement: step 9, image 1 of 2 HyperX Alloy Origins Key Switch Replacement: step 9, image 2 of 2
      • Flip the keyboard over to face the PCB.
      • Identify the corresponding switch to be removed.
      Ask FixBot
    3. HyperX Alloy Origins Key Switch Replacement: step 10, image 1 of 1
      • Plug in and turn on your soldering iron.
      • Do not touch the metal end of the soldering iron while it is powered on. Allow the soldering iron to cool before stowing it away.
      Ask FixBot
    4. HyperX Alloy Origins Key Switch Replacement: step 11, image 1 of 3 HyperX Alloy Origins Key Switch Replacement: step 11, image 2 of 3 HyperX Alloy Origins Key Switch Replacement: step 11, image 3 of 3
      Tool used on this step:
      Desoldering Pump
      $3.99
      Buy
      • Melt the solder surrounding the four pins of the switch's LED, and the two lower pins of the switch body.
      • To remove the melted solder, use a desoldering iron, a desoldering pump, or desoldering braid.
      • The exposed switch pins are susceptible to damage from the soldering iron. Avoid applying heavy pressure to mitigate pin bending.
      Ask FixBot
    5. HyperX Alloy Origins Key Switch Replacement: step 12, image 1 of 1
      • Using a spudger or another metallic instrument, firmly press down upon the exposed plastic of the switch. This will separate the switch from the rest of the keyboard.
      • If the switch's pins will not separate from the keyboard's PCB, continue applying the soldering iron to the pins to melt any residual solder.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Note that when reattaching the switch back to the keyboard PCB, the switch needs to be held in place behind the keyboard while soldering.
7 other people completed this guide.
Cameron Michaels
169 Reputation
1 Guide authored
UMass Dartmouth, Team 5-2, Sinclaire Fall 2022 Member of UMass Dartmouth, Team 5-2, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S5G2
5 Members
72 Guides authored
7 Guide Comments
Hi, I needed to replace the stabilizers for my spacebar and was able to repaire it successfully by removing the spacebar switch and using the stabilizers from the + key on the keypad which I dont care about. But now when I plug in the keyboard, there's no power at all and no input. If I didn't solder the spacebar switch back on properly, could this cause the whole keyboard to stop working? Also, I decided not to put the + switch back on since I wouldnt be using it anyway.
André Léger - Reply Share
I need to replace some switches on the same keyboard and I don't know yet. where to buy it or what is the switch model or manufacturer, could you help me with that information?
Gerardo - Reply Share
Holaaa ando buscando un diagrama del circuito del teclado, ya que al cambiar un led una parte del teclado solo ilumina color rojo y los demas iluman en rgb :C
Francisco Alcalá - Reply Share
The W key isn’t working on my sons HyperX Alloy Origins Keyboard… he’s cleaned underneath all keys for any debris and tried pressing the escape and function keys at the same time to try and reset plus tried plugging the usb into another port but W key still doesn’t work. Any other suggestions? Can you buy a replacement W key for this keyboard?
A_J - Reply Share
Past 24 Hours: 16
Past 7 Days: 130
Past 30 Days: 567
All Time: 36,966
