HyperX Alloy Origins Backplate Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
97
All Time:
2,238
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show how to remove the backplate from your HyperX Alloy Origins mechanical keyboard (serial number HX-KB6RDX and its variants).
The HyperX Alloy Origins mechanical keyboard, like many other keyboards, requires backplate removal before accessing many of its other internal components. Be sure to visit the troubleshooting page first before determining that a part needs to be replaced! Otherwise, this guide will help you in what is often the first step in repairing your HyperX Alloy Origins keyboard.
Before removing the backplate, make sure the keyboard is disconnected from your device and that the LED’s are not on. Avoid using excessive force during disassembly to prevent damaging any of the keyboard’s components. Work on a solid, hard surface, and ground yourself occasionally during disassembly to mitigate electrostatic discharge from your hands, which could damage internal keyboard components.
Tools
  • Spudger
    4.9
  • Phillips #00 Screwdriver
    4.9
    1. HyperX Alloy Origins Backplate Replacement, Toggle Indicator Tab: step 1, image 1 of 1
      • Locate the toggle indicator tab on the top right corner of the keyboard.
      Ask FixBot
    2. HyperX Alloy Origins Backplate Replacement: step 2, image 1 of 2 HyperX Alloy Origins Backplate Replacement: step 2, image 2 of 2
      • Insert the metal spudger or some other separating instrument into the right crevasse between the tab and the keyboard.
      • Lift up gently on the tab, while holding the left side of the tab down.
      • The tab can spring upwards upon removal. Eye protection is recommended during this step.
      Ask FixBot
    1. HyperX Alloy Origins Backplate Replacement, Backplate: step 3, image 1 of 2 HyperX Alloy Origins Backplate Replacement, Backplate: step 3, image 2 of 2
      • Flip the keyboard over so that the backplate is facing you.
      Ask FixBot
    2. HyperX Alloy Origins Backplate Replacement: step 4, image 1 of 3 HyperX Alloy Origins Backplate Replacement: step 4, image 2 of 3 HyperX Alloy Origins Backplate Replacement: step 4, image 3 of 3
      • Remove the rubber feet on the four corners of the backplate.
      • When reassembling, use an adhesive to reattach the feet. A silicone rubber adhesive is recommended.
      Ask FixBot
    3. HyperX Alloy Origins Backplate Replacement: step 5, image 1 of 3 HyperX Alloy Origins Backplate Replacement: step 5, image 2 of 3 HyperX Alloy Origins Backplate Replacement: step 5, image 3 of 3
      • Remove the specified keycaps as depicted in the image.
      Ask FixBot
    4. HyperX Alloy Origins Backplate Replacement: step 6, image 1 of 3 HyperX Alloy Origins Backplate Replacement: step 6, image 2 of 3 HyperX Alloy Origins Backplate Replacement: step 6, image 3 of 3
      • Remove all Philips #0 screws from the new openings created after removing the rubber feet and plastic tab.
      Ask FixBot
    5. HyperX Alloy Origins Backplate Replacement: step 7, image 1 of 3 HyperX Alloy Origins Backplate Replacement: step 7, image 2 of 3 HyperX Alloy Origins Backplate Replacement: step 7, image 3 of 3
      • Separate the backplate from the keyboard using your hands.
      Ask FixBot
Mario Ricci
294 Reputation
2 Guides authored
UMass Dartmouth, Team 5-2, Sinclaire Fall 2022 Member of UMass Dartmouth, Team 5-2, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S5G2
5 Members
72 Guides authored
1 Guide Comment
my plate was scratched due to being separated using a metal screw driver, do you have any recommended paints to go over the scratched areas with?
Damian Burton - Reply Share
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 97
All Time: 2,238
