Ice makers typically fail for a few reasons, and if your ice maker isn't making ice, only crushing ice, not dispensing ice, or won't stop making ice, review the hyperlinked guides first. After resetting power to the refrigerator, if you still don't have ice after a 24 hour period, you may have to reset the ice maker.
Use the On/Off Switch or Reset Button
Put rags and the ice bucket beneath your ice maker to prevent water from accumulating during these tests.
  • Flip the ice maker switch off for 5 seconds, then flip it on.
  • Press and hold the reset button for 5 seconds.
  • Cycle the feeler arm up and down several times.
The unit should be in test mode now and will run a manual ice harvest cycle. Watch as the arm moves, and the tray dumps or otherwise ejects cubes. A fill cycle will then start. Your ice maker has been reset.
If it still does not work after further troubleshooting, consider replacing the upper ice maker or ice maker located in the freezer.
Discussion: LG Ice Maker Reset Location
Troubleshooting: LG Ice Maker Not Making Ice
How to: Maintain a Refrigerator
How to: Defrost an Ice Maker
Author
with
Bill Gilbert
41,141 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
5 Comments
My lg is making ice but won’t dump. When I press the reset button it dumps but otherwise won’t. Do I need to replace it or is there something else to be done to fix?
bcoddy - Reply Share
Do you got any answer l? Im having the same problema
Ricardo Gomez - Reply Share
My lower ice maker and ice ball. Maker are not making ice. How do I fix that?
Mighty Eskimo Quinn - Reply Share
I started pressing the reset button regularly like 2,3or4 times a day. It has mysteriously started working again. Don’t jinx me.
Where is the reset button located?
Rick Laman - Reply Share
Past 24 Hours: 10
Past 7 Days: 54
Past 30 Days: 208
All Time: 13,648
