LG Refrigerator Freezer Ice Maker Replacement
Views: 10K
View statistics:
Past 24 Hours:
8
Past 7 Days:
64
Past 30 Days:
367
All Time:
10,499
Comments: 7
7 comments on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to replace the freezer ice maker on your LG refrigerator.
This guide will work for most LG refrigerators. This guide is written with an LG model LFX25973 refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
The freezer ice maker provides a supply of ice stored in your freezer drawer.
When the freezer ice maker malfunctions, you will not have ice available in the ice bucket in the freezer drawer.
Tools
    1. LG Refrigerator Freezer Ice Maker Replacement, Unplug your refrigerator: step 1, image 1 of 1
      • Unplug your refrigerator before you begin your repair.
      • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
      • Condenser fan motor
      • Compressor motor and thermal overload device
      • Water supply valve assembly
      Ask FixBot
    1. LG Refrigerator Freezer Ice Maker Replacement, Open the freezer door: step 2, image 1 of 2 LG Refrigerator Freezer Ice Maker Replacement, Open the freezer door: step 2, image 2 of 2
      • Pull open the freezer door fully.
      Ask FixBot
    2. LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer and bin: step 3, image 1 of 3 LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer and bin: step 3, image 2 of 3 LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer and bin: step 3, image 3 of 3
      • Lift and remove the upper pull-out drawer.
      • Lift and remove the main drawer bin.
      Ask FixBot
    3. LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer rail covers: step 4, image 1 of 3 LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer rail covers: step 4, image 2 of 3 LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer rail covers: step 4, image 3 of 3
      • Use your finger or a flat-blade screwdriver to depress the two locking tabs on the right drawer rail cover.
      • Lift the cover off of the rail and remove it.
      • Repeat this procedure for the left drawer rail cover.
      Ask FixBot
    4. LG Refrigerator Freezer Ice Maker Replacement, Reassembly notes: step 5, image 1 of 2 LG Refrigerator Freezer Ice Maker Replacement, Reassembly notes: step 5, image 2 of 2
      • The drawer rail covers can be tricky to reinstall. Follow these steps to reinstall them:
      • Hold the drawer rail cover flush against the side of the drawer rail.
      • You should feel the locking tabs protruding.
      • Push the rail cover straight downward to install. It should click into place.
      Ask FixBot
    5. LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer: step 6, image 1 of 2 LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer: step 6, image 2 of 2
      • Use a Phillips screwdriver to remove the screw securing the drawer to each of the drawer slides.
      Ask FixBot
    6. LG Refrigerator Freezer Ice Maker Replacement: step 7, image 1 of 3 LG Refrigerator Freezer Ice Maker Replacement: step 7, image 2 of 3 LG Refrigerator Freezer Ice Maker Replacement: step 7, image 3 of 3
      • Lift the front of the drawer up.
      • Pull the drawer toward you to release the drawer from the drawer slides.
      • Remove the freezer drawer.
      Ask FixBot
    1. LG Refrigerator Freezer Ice Maker Replacement, Release the ice maker: step 8, image 1 of 1
      • Use a Phillips screwdriver to remove the screws securing the ice maker to the top of the freezer compartment.
      Ask FixBot
    2. LG Refrigerator Freezer Ice Maker Replacement: step 9, image 1 of 3 LG Refrigerator Freezer Ice Maker Replacement: step 9, image 2 of 3 LG Refrigerator Freezer Ice Maker Replacement: step 9, image 3 of 3
      • Insert a flat-blade screwdriver into the slot located on the right edge of the ice maker.
      • Pry outward with the screwdriver to release the locking tab securing the ice maker to the fridge.
      • When the tab releases, pull the right front corner of the ice maker down.
      Ask FixBot
    3. LG Refrigerator Freezer Ice Maker Replacement: step 10, image 1 of 1
      • Repeat the previous operation on the left side of the ice maker to release it.
      Ask FixBot
    4. LG Refrigerator Freezer Ice Maker Replacement: step 11, image 1 of 3 LG Refrigerator Freezer Ice Maker Replacement: step 11, image 2 of 3 LG Refrigerator Freezer Ice Maker Replacement: step 11, image 3 of 3
      • Grasp the front edge of the ice maker and pull it towards you.
      • Lower the ice maker.
      Ask FixBot
    5. LG Refrigerator Freezer Ice Maker Replacement, Disconnect and remove the ice maker: step 12, image 1 of 3 LG Refrigerator Freezer Ice Maker Replacement, Disconnect and remove the ice maker: step 12, image 2 of 3 LG Refrigerator Freezer Ice Maker Replacement, Disconnect and remove the ice maker: step 12, image 3 of 3
      • Squeeze the ice maker connector to release it and pull it straight out to disconnect it.
      • Remove the ice maker.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
4 other people completed this guide.
Bill Gilbert
40,642 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 64
Past 30 Days: 367
All Time: 10,499
