LG Refrigerator Upper Ice Maker Assembly Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
4
Past 7 Days:
40
Past 30 Days:
152
All Time:
1,816
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to replace the upper ice maker assembly in an LG refrigerator.
This guide will work for most LG refrigerators. This guide is written with an LG model LFX25973 refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
The upper ice maker provides the ice and the feed mechanism for the through-the-door ice and water dispenser. The assembly includes the upper ice maker, a backing plate, and the ice auger motor which is incorporated into the backing plate.
When it fails, the dispenser will not be able to dispense cubes or crushed ice.
Tools
    1. LG Refrigerator Upper Ice Maker Assembly Replacement, Unplug your refrigerator: step 1, image 1 of 1
      • Unplug your refrigerator before you begin your repair.
      • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
      • Condenser fan motor
      • Compressor motor and thermal overload device
      • Water supply valve assembly
      Ask FixBot
    1. LG Refrigerator Upper Ice Maker Assembly Replacement, Open the doors: step 2, image 1 of 3 LG Refrigerator Upper Ice Maker Assembly Replacement, Open the doors: step 2, image 2 of 3 LG Refrigerator Upper Ice Maker Assembly Replacement, Open the doors: step 2, image 3 of 3
      • Open both refrigerator doors fully.
      Ask FixBot
    1. LG Refrigerator Upper Ice Maker Assembly Replacement, Remove the ice maker assembly screws: step 3, image 1 of 2 LG Refrigerator Upper Ice Maker Assembly Replacement, Remove the ice maker assembly screws: step 3, image 2 of 2
      • Use a #2 Philips driver to remove the screws that secure the ice maker assembly to the refrigerator door.
      Ask FixBot
    2. LG Refrigerator Upper Ice Maker Assembly Replacement, Reposition the ice maker assembly: step 4, image 1 of 3 LG Refrigerator Upper Ice Maker Assembly Replacement, Reposition the ice maker assembly: step 4, image 2 of 3 LG Refrigerator Upper Ice Maker Assembly Replacement, Reposition the ice maker assembly: step 4, image 3 of 3
      • Use a spudger to lift the bottom edge of the ice maker assembly. This action will release the assembly from the refrigerator door.
      • Pull the bottom edge of the ice maker assembly toward you to free it from the door.
      Ask FixBot
    3. LG Refrigerator Upper Ice Maker Assembly Replacement: step 5, image 1 of 3 LG Refrigerator Upper Ice Maker Assembly Replacement: step 5, image 2 of 3 LG Refrigerator Upper Ice Maker Assembly Replacement: step 5, image 3 of 3
      • Lower the ice maker assembly until you can access the connector located at the top of the assembly.
      • Squeeze the connector at the top of the ice maker assembly to release it.
      • Pull the connector straight down to disconnect it.
      Ask FixBot
    4. LG Refrigerator Upper Ice Maker Assembly Replacement, Remove the ice maker assembly: step 6, image 1 of 1
      • Remove the ice maker assembly.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
40,642 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 40
Past 30 Days: 152
All Time: 1,816
