Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The Blender Will Not Turn On
When you turn on the blender the blades do not turn.
The blender is not plugged in
Make sure the power button is not being pushed, then make sure the power cord is properly plugged into a functioning power outlet. If the blender was not completely secured in the power outlet, properly plug it in the power outlet. Proceed to use the blender for its intended use.
The power cord has short-circuited
Check the power cord to see if there are any tears or damage, if so, you can attempt to replace the power cord using this guide. If the problem persists, then there may be another issue at hand. Continue reading the listed causes.
The power button is stuck or unresponsive
If the power cord is plugged and has not short-circuited, the power button might be stuck or unresponsive. You can use this guide to check inside the blender and remove any blockage or repair any damage to the internal wires.
The motor has overheated
If the blender is not functioning after checking the previous causes, the issue might be that the motor has overheated. In the case that the motor has overheated, you will need to buy a replacement motor and then replace the current motor with the replacement motor using this guide.
The Blades Will Not Spin
When the blender is being used, the blades do not work.
Blender has become unplugged
Check to see if the cord to the blender did not get unplugged while using the blender. If the blender is not plugged in, plug it back in and turn it on once more.
Food is jammed between the blades
Solids like ice and frozen fruit might have stopped the blades from turning. Turn off the blender and unplug it. Open the blender and carefully remove any solids from under the blades to avoid injury. Then close the blender, plug it back in, and turn it on.
The power cord might have stopped functioning. In order to fix it, you must repair the power cord using this guide.
The motor overheated
The motor might have stopped working. In order to repair it, you must replace the motor by following this guide.
The Blender is Smoking
During use, the blender begins smoking and might have stopped working abruptly
Food is jamming the blades
Make sure the blender is turned off and unplugged. Check the container for any food particles that may be obstructing the blades. Carefully remove the food particles with a spoon to prevent hand injury. After the obstruction is cleared plug the blender into an outlet and turn the blender on to ensure that it working.
Make sure the blender is turned off an unplugged. Check the power cord to see if any wires are damaged. If there is damage use this guide to replace the power cord. If this does not fix the problem there may be another issue than needs to be addressed.
If the blender does not work after checking the previous symptoms above, it may be the motor fan. Replace the motor fan using this guide.
The Blender is plugged into a 230V plug without a transformer.
For international travelers: ensure your adapter also has a transformer built in.
The Blender is Not Fully Blending
The ingredients in the blender are not getting blended or getting jammed, leaving large chunks.
Make sure the blender is unplugged. Check to make sure that food or other ingredients aren’t jamming the blades. If there is food obstructing the blades, carefully remove the food with a fork or spoon to ensure you don’t cut yourself on the blade. With food no longer jamming the blade, it is safe to plug the blender back in to continue its use.
The blades have dulled or broke
Make sure the blender is unplugged. Do not rub your hands or fingers on the blade to avoid cutting yourself. Visibly check to see if the blades are dull. If the blades are dull, buy a new blade and replace the blade using this guide.
The Blender is Leaking
As you’re blending, you notice liquid starting to spill from out of the container.
The lid is not secured
If there’s liquid leaking from the top of the container, the lid might not be properly secured to the container. Make sure the drinking hole is closed and the lid is fully pressed to the container.
The container may have cracks
Check to see if the leak is coming from somewhere other than the top. If so, the container might be cracked or broken and will need to be replaced.
Author
with
Andrew Huff
655 Reputation
3 Guides authored
USF Tampa, Team 2-5, Sullivan Fall 2015 Member of USF Tampa, Team 2-5, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G5
4 Members
60 Guides authored
21 Comments
so where can you get the container from?
itsshortforleo - Reply Share
Blender suddenly stopped working. Blue light turns on as do all function lights but blender will not work. Any suggestions. I don’t want to purchase a new one as this has only been used a handful of times and I don’t consider it to be disposable.
Heidi Tyrcha-Huth - Reply Share
The blade is stuck and will no longer turn. Even by hand it will only turn with the use of a wrench. I don’t see this problem addressed in this article anywhere.
Chris Cooper - Reply Share
The blade is lose and leaking wath parts I need and wear can I getting
papi3701@aol.com - Reply Share
I ust bought the blender and the lid is stuck on. I can see the locks but they will not unlock..
Robbie lamons - Reply Share
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 97
All Time: 34,466
