Hamilton Beach 51101BA Blades Replacement
    1. Hamilton Beach 51101BA Blades Replacement, Blades: step 1, image 1 of 1
      • Remove the lid from the container by holding the base and pulling up on the lid.
      Ask FixBot
    2. Hamilton Beach 51101BA Blades Replacement: step 2, image 1 of 3 Hamilton Beach 51101BA Blades Replacement: step 2, image 2 of 3 Hamilton Beach 51101BA Blades Replacement: step 2, image 3 of 3
      • Remove the container from the blender.
      • Hold the blender and the container, then twist the container in a clockwise motion.
      • Make sure to follow the lock and unlock markings on the container.
      Ask FixBot
    3. Hamilton Beach 51101BA Blades Replacement: step 3, image 1 of 3 Hamilton Beach 51101BA Blades Replacement: step 3, image 2 of 3 Hamilton Beach 51101BA Blades Replacement: step 3, image 3 of 3
      • Avoid placing your fingers on the blade, as they could be sharp.
      • Using a pair of pliers to hold the blade in place, use your other hand to unscrew the rubber piece on the bottom of the container.
      • Remove the rubber piece and the two washers by rotating the rubber piece counter-clockwise.
      Ask FixBot
    4. Hamilton Beach 51101BA Blades Replacement: step 4, image 1 of 1
      • Carefully, pull the blades out of the container as they are very sharp.
      • Using the pliers, remove blades and the washer around the blade shaft.
      Ask FixBot
To reassemble your device with the new blade assembly, follow these instructions in reverse order.
7 other people completed this guide.
Brandon Nunez
301 Reputation
2 Guides authored
USF Tampa, Team 2-5, Sullivan Fall 2015 Member of USF Tampa, Team 2-5, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G5
4 Members
60 Guides authored
3 Guide Comments
Need to know how to install parts and how many
papi3701@aol.com - Reply Share
Looks like I missed parts need to know the order son cuantaty
For my 501101B blender, the whole blade assembly popped out, so the blended smoothie draws at the bottom like a water falls How to fix this?
Joyful Joy - Reply Share
Past 24 Hours: 3
Past 7 Days: 37
Past 30 Days: 185
All Time: 14,305
