Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Not Connecting to Base Station
Vive controller is powered on but does not respond during gameplay
If LED is Blue
If the Vive controller is powered on and a blue LED appears on the controller, your controller is not connected properly to your PC. To pair your Vive controller with your PC again, follow these steps: Open Steam VR. Click on the drop down menu and select Devices. From the Devices tab, click Pair Controller. Follow posted instructions to pair your HTC Vive controller with your PC.
If LED is Red
If the controller LED is a constant red, it may be unresponsive and in need of resetting. Hold down the trigger, menu button, trackpad button, and grip buttons simultaneously. While buttons are still pressed, plug the controller into your PC. Five seconds after plugging in, release the buttons. A prompt will appear on your PC to search for a new storage. Ignore this prompt and unplug the controller. The controller should now be reset and functioning properly.
If LED is Not On
If the controller is not displaying a lit LED, the controller is off. Press the system button to turn on the controller. If the LED doesn’t illuminate, your controller may need to be charged. Attach your MicroUSB cable and power adaptor to the controller and plug into an outlet. While charging, the controller LED will display different colors. Orange means the Controller is charging. Green means the battery is fully charged and the power is on. White means the battery is fully charged and the power is off.
Controller is Out of Range
You must be positioned between both base stations in order to connect.
Remote Sensor No Longer Tracks
Controller is connected to base station, but does not interact with the game environment
Ribbons Disconnected from Motherboard
If you’ve dropped the controller or accidently hit it against something, then the infrared sensor ribbon cables may be disconnected from the motherboard. Please refer to our Front Panel Replacement Guide for information on how to access these cables. Plug the cables back into their respective ports and reassemble your controller.
Sensor Lenses are Blocked
Dirt and dust can block the sensor lense. Wipe the sensor lenses with a damp, clean cloth. Only dampen the cloth with water.
Sensor Lenses are Scratched
Scratch marks on the lenses can block the sensor. If you see scratches on the lenses, the saucer should be replaced. Please refer to our Saucer Replacement Guide.
Sticky Buttons
Buttons do not move, get stuck when pressed, or are performing inadequately
Dirt Jamming Buttons
Dirt or other foreign material may be stuck in the button’s path. Please refer to our Trigger, Front Panel Buttons, or Grip Buttons Replacement Guide for information on how to access the affected area. Once you access the area, carefully clean it with an air-duster, brush or cloth before reassembling. If necessary you may need to use rubbing alcohol lightly to clean the affected area.
Controller Not Turning On
When the system button is pressed and held there is no beeping sound, no LEDS on the controller light up, and the controller doesn’t track
Remote is Not Powered On
To turn the controller on, hold the System Button until you hear a beeping sound.
Battery is Not Charged
If the controller’s LED lights fail to turn on, or if the lights begin flashing red then the remote battery may need to be charged. Plug the supplied charger into the micro-USB port located on the end of the controller opposite the halo. If you do not have the supplied charger, you can use any micro-USB and USB to wall adapter. While charging, the LED lights will turn orange and once the controller is fully charged, the LED lights will turn white.
Power Button has Dirt or Sticky Residue
If the power button does not move, gets stuck when pressed, or is performing inadequately, then there may be dirt or other foreign material stuck in the button’s path. You can access the power button area using the “Front Panel Buttons” replacement guide. Once you have access to the area, carefully clean it with an air-duster or cloth before reassembling. If necessary you may need to use rubbing alcohol lightly to clean the affected area.
Battery is Not Connected Properly
If the device isn’t powering on after charging for several hours and the LEDs are not lighting up, then you may need to check if the battery is connected. Follow steps to access the battery in the Battery Replacement Guide. Check to see if the white, red, and black 3-pin cable that connects the battery to the daughter board is connected properly. If the cable is loose or disconnected, then firmly connect it to the black 3-pin port.
Battery is Defective or is No Longer Holding a Charge
If the device isn’t powering on after charging for several hours and the LEDs are not lighting up, then you may need to replace the battery. Follow steps to replace the battery in the Battery Replacement Guide.
Touchpad Unresponsive
Trackpad is unresponsive when it is clicked. The trackpad is unresponsive when a finger is placed upon and moved over the trackpad surface.
Check the power of your remote, make sure it is ON. Your controller is on if it is connected to the headset. The Vive controller is on when the LED light flashes upon pressing the menu or system button. To turn on the controller, hold the System Button until you hear a beep and the LED light turns blue.
Trackpad Has Dirt Build Up or Sticky Residue
If you press the trackpad button and it does not move, there may be dirt or sticky residue from snacks underneath the trackpad. You will need to follow the guide Front Panel Buttons Replacement Guide to clean out the dirt or sticky residue below the trackpad.
Trackpad is Unresponsive to Touch
If you move your finger upon the trackpad surface and there is no response, you will need to replace the trackpad. Follow the steps in Front Panel Buttons Replacement Guide to replace the trackpad button.
Author
with
Ryan Grewohl
893 Reputation
3 Guides authored
Cal Poly, Team S15-G5, Livingston Fall 2017 Member of Cal Poly, Team S15-G5, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G5
4 Members
96 Guides authored
14 Comments
Hi,
My controller Vive Controller 2.0 (blue) won’t connect to PC properly, -> blinking Red Led
Paring works, charging works, but even with power cable it won’t connect (show green) in SteamVr.
Already Check all Cables inside,
 reconnect the Battery,
 no effects, any suggestions?
Thanks
Felix Ernst - Reply Share
I have the same problem, have you found a solution?
Arnar Arason - Reply Share
Exactly the same problem here, red, slowly flashing LED on one of my controllers:
1. I charged the controller for 3 days now, using the original charger (tested on other controller and verified to be working) and with an alternative charger (also tested and found to be working with other controller).
2. I can also start the pairing mode on the controller (start search on the PC, hold the two buttons, LED flashes blue, but it doesn’t pair…
3. I tried the reset thing where you hold all buttons apart from the bottom one, plug it in to the computer, the LED starts flashing orange rapidly, let go of the buttons, unplug the cable; no change, as soon as you turn it on again the LED flashes red slowly.
4. I even physically disconnected and reconnected the battery and there was no change.
Has anyone found a solution for this?
DrMagicWolf - Reply Share
I have the exact same problem started 5 days ago too. Weird. Flashes red after pair. When charging it's solid white indicating it's fully charged. How ever after pairing process starts flashing red again
fEYEtingIRISH - Reply Share
Does replacing the battery works for this case?
Andrew - Reply Share
Past 24 Hours: 6
Past 7 Days: 24
Past 30 Days: 130
All Time: 37,672
