Introduction
Go to step 1 ↓Use this guide to remove or replace the front panel on the HTC Vive controller. Be careful not to tear the ribbon cables or any of the connectors they correspond to while removing the front panel.
Turn over the Vive controller so that the bottom saucer is facing up.
Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer.
Use the T5 Torx screwdriver to remove the two black 5.2mm screws on the back gray panel.
11 other people completed this guide.
