HTC Vive Controller Saucer Replacement
    1. HTC Vive Controller Saucer Replacement, Saucer Panels: step 1, image 1 of 3 HTC Vive Controller Saucer Replacement, Saucer Panels: step 1, image 2 of 3 HTC Vive Controller Saucer Replacement, Saucer Panels: step 1, image 3 of 3
      • Turn over the Vive controller so that the bottom saucer is facing up.
      • Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer.
      Ask FixBot
    2. HTC Vive Controller Saucer Replacement: step 2, image 1 of 2 HTC Vive Controller Saucer Replacement: step 2, image 2 of 2
      • Use the nylon spudger to separate the top and bottom saucer covers all around the edges.
      • Remove only the top saucer cover by pulling up with your hand.
      Ask FixBot
    3. HTC Vive Controller Saucer Replacement: step 3, image 1 of 2 HTC Vive Controller Saucer Replacement: step 3, image 2 of 2
      • Use the Phillips 00 screwdriver to remove the three silver 12.8mm screws from the exposed upper sensor panel.
      Ask FixBot
    4. HTC Vive Controller Saucer Replacement: step 4, image 1 of 3 HTC Vive Controller Saucer Replacement: step 4, image 2 of 3 HTC Vive Controller Saucer Replacement: step 4, image 3 of 3
      • Carefully pull away the bottom saucer cover with your hand.
      • To aid in removing the saucer cover, squeeze the base of the controller with your other hand, as shown in the second image of this step. Squeezing will make the clips easier to release and help prevent them from breaking.
      Ask FixBot
6 other people completed this guide.
Ryan Grewohl
893 Reputation
3 Guides authored
Cal Poly, Team S15-G5, Livingston Fall 2017 Member of Cal Poly, Team S15-G5, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G5
4 Members
96 Guides authored
3 Guide Comments
Where do you get the replacement parts?
dmitri.walker - Reply Share
Vive dont less these parts we need to 3D print them its a Nightmare RN for business especially arcades
superseani2 - Reply Share
My controller only has 2 screws that are different sizes than a t5 and the 3rd is completely covered up by plastic. I have the sticky button problem, halp pls
bizkidjordan - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 47
All Time: 7,333
