Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The device is not connecting to the headset
The controllers will not pair with the headset.
Previous Bluetooth Pairings
Check to see if your laptop already has a device paired to it. If so, disconnect that device and try to pair the controllers again. Having a device already paired to your laptop will prevent you from pairing a new one.
To pair the device, open the Mixed Reality Portal on your laptop. Go to the sidebar and select “pair controllers”. Open the battery cover and hold down the small button below the battery for two seconds. The controllers should appear on your laptop screen, select pair.
Low Battery
If the controllers aren’t pairing to the headset, attempt to replace the batteries. To check the battery level, turn the controllers over to see the battery icon. If the icon is red, go ahead and replace the batteries and wait about 30 seconds before repairing. A battery replacement guide can be found here.
The device is not tracking motion
The controllers do not track motion accurately or cannot track at all.
Excess light in the room is interfering with the lights in the controllers and the sensors in the headset.
Try blocking direct sunlight coming from your windows. Clearing your play area of other sources of disorienting light can help as well. If tracking is still presenting issues, you may need to re-sync your controllers or reestablish your Bluetooth connections.
To repair the device, open the Mixed Reality Portal on your laptop. Go to the sidebar and select “pair controllers”. Open the battery cover and hold down the small button below the battery for two seconds. The controllers should appear on your laptop screen, select pair.
The system is unable to render all displayed frames and fills in unprocessed areas with black. The system may be under resource contention.
Make sure the application is not competing with other programs for computing resources. Close unneeded programs to free up memory and GPU. Reducing detail settings in the application and Windows Mixed Reality settings can alleviate stress on the CPU and GPU.
Make sure the latest graphics drivers are installed. These can be found on the websites for your GPU or PC manufacturer.
The controllers are not turning on
The controller(s) does not power on when the whole system is powered up.
The batteries may not have been inserted correctly or the batteries are dead
Remove the panel under the handle by sliding it in the direction of the arrow. This will reveal the battery compartment. Check to see if batteries are inserted. If not, insert the AA batteries the device needs.
Check that the batteries are oriented correctly. The positive end of the battery should be in contact with the positive terminal (the side with the ‘+’ sign) and the negative end should be in contact with the negative terminal (the side with the ‘-’ sign).
If batteries are inserted correctly and the device still won’t power on, try replacing the batteries with new ones, for which a guide can be found here.
The terminals are corroded and current is unable to flow freely
In some cases, replacing the batteries still does not fix the issue. Check to see if corrosion has occurred in the terminals. White, green, or yellow deposits can indicate current is unable to flow freely. Clean the terminals with a cotton swab and a small amount of white vinegar. Repeat as necessary until all white residue is removed.
The trigger button is not functioning properly
The trigger button, located on the top left of the controller, is not responding and doesn’t bounce back.
The button itself is jammed inside the body of the controller
In order to fix this problem, follow the following instructions to open up the WMR controller and tighten the button:
Pull the joystick up until it and the controller’s top panel separate. Once both are off, unscrew the screw located at the joystick well. Unscrew the four screws in the battery compartment. The top and bottom halves of the controller should separate easily. Locate the trigger button on the top of the controller and pull it out. Move the spring (beneath the trigger button) around so that the latch will bend further and tighten the button to prevent it from getting caught in the controller. Test the button without putting the pieces together first. Once the button is secure, screw everything back into place.
If additional help is needed, check the trigger button replacement guide here.
There is a software issue due to new updates
A few of Microsoft’s older updates have caused the trigger button and joystick to not respond in SteamVR. A simple way to fix this problem, one provided by Steam support, is to close Steam and delete the steamvr.vrsettings file. By default, the file will be located in C:\Program Files (x86)\Steam\config.
The joysticks are not functioning properly
The joysticks on the controllers are not responding to actions by the user.
A few of Microsoft’s older updates have caused the trigger button and joysticks to not respond in SteamVR. A simple way to fix this problem, provided by Steam support, is to close Steam and delete the steamvr.vrsettings file. By default, the file will be located in C:\Program Files (x86)\Steam\config.
The joystick has lost its range of motion
As with the trigger button, pull by the joystick until the top panel and joystick separate from the controller. Underneath, there should be a screw located at the top of the joystick well. After unscrewing it, locate the battery compartment at the bottom of the controller and unscrew the four screws located inside. This should separate the top and bottom half.
A common solution associated with this joystick problem is to take a small dry tissue or towel and clean the parts of the controller to ensure there is no debris limiting the joystick’s range of motion. If that doesn’t work, move the shaft underneath the joystick around to see how fluid it is. If the shaft is the problem, the joystick component must be replaced and the guide for that can be found here.
Author
with
Seiji Nagasawa
219 Reputation
1 Guide authored
Cal Poly, Team S18-G5, White Winter 2019 Member of Cal Poly, Team S18-G5, White Winter 2019
CPSU-WHITE-W19S18G5
2 Members
72 Guides authored
2 Comments
Hello! I have an HP WMR set that I’ve successfully used for about two years now. After a reinstall of my OS, my PC will no longer see the left controller when attempting to pair. The right controller and the visor work fine, it’s just the left one that’s a problem. The lights on the controller pulse when in pairing mode, so I’m not sure what the issue is. Any help you can provide would be greatly appreciated!
Jered Gordner - Reply Share
gday i have had my wmr set for a while now and havent had a problem until now ,whenever i try to use it the head set turns on no problem but when i turn on the controllers my screen goes crazy with multiple screens opening including an onscreen keyboard,ive tried repairing ,new batteries ,rebooting and everything ,the only thing that works is turning them off ...any ideas???
Mark waters - Reply Share
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 41
All Time: 1,776
