HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
0
Past 7 Days:
8
Past 30 Days:
66
All Time:
2,081
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide goes over how to replace the controller's trigger button.
If your TPC-Q044 trigger button starts failing when using your controller, you may want to think about replacing the component. The failure may be a result of a loose spring or a broken latch. The replacement of the circuit board is not too complex. You will need the indicated screwdrivers and a spudger to complete this task. There are no warnings or potential hazards when replacing the pad.
Tools
  • Spudger
    4.9
  • Phillips #00 Screwdriver
    4.9
    1. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: step 1, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: step 1, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: step 1, image 3 of 3
      • Slide the rear compartment cover in the direction of the arrow.
      • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
      Ask FixBot
    1. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Shell: step 2, image 1 of 2 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Shell: step 2, image 2 of 2
      • Remove the four 4mm screws using a Phillips #00 screwdriver.
      Ask FixBot
    2. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: step 3, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: step 3, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: step 3, image 3 of 3
      • Grip the main body and pull the joystick outwards until the entire front panel pops off.
      • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
      Ask FixBot
    3. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: step 4, image 1 of 2 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: step 4, image 2 of 2
      • Use a spudger to pry apart the two halves of the assembly.
      • Work slowly, prying a small section at a time until the halves are completely separated.
      Ask FixBot
    1. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: step 5, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: step 5, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: step 5, image 3 of 3
      • Grasp the trigger with one hand while pushing against the outer wall of the shell.
      • Apply pressure, pulling the wall away from the trigger.
      • Remove the trigger starting from the freed edge.
      • The spring-rod assembly can easily come apart. Inserting the large end first during reassembly may make the process easier.
      Ask FixBot
4 other people completed this guide.
Clement Cheung
643 Reputation
5 Guides authored
Cal Poly, Team S18-G5, White Winter 2019 Member of Cal Poly, Team S18-G5, White Winter 2019
CPSU-WHITE-W19S18G5
2 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 66
All Time: 2,081
