HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement
  1. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Batteries: step 1, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Batteries: step 1, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Batteries: step 1, image 3 of 3
    • Slide the rear compartment cover in the direction of the arrow.
    • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
    Ask FixBot
  2. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Shell: step 2, image 1 of 2 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Shell: step 2, image 2 of 2
    • Remove the four 4mm screws using a Phillips #00 screwdriver.
    Ask FixBot
  3. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: step 3, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: step 3, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: step 3, image 3 of 3
    • Grip the main body and pull the joystick outwards until the entire front panel pops off.
    • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
    Ask FixBot
  4. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: step 4, image 1 of 2 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: step 4, image 2 of 2
    • Use a spudger to pry apart the two halves of the assembly.
    • Work slowly, prying a small section at a time until the halves are completely separated.
    Ask FixBot
  5. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Small Circuit Board: step 5, image 1 of 2 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Small Circuit Board: step 5, image 2 of 2
    • Using a Phillips #00 screwdriver, remove the four 4mm screws located on the joystick circuit board underneath the top half of the controller.
    Ask FixBot
  6. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: step 6, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: step 6, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: step 6, image 3 of 3
    • Remove the orange flat cable by pulling the orange tab parallel to the circuit board.
    • Release the blue flat cable by lifting up the white latch with a spudger.
    Ask FixBot
  7. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Joystick Switch: step 7, image 1 of 2 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Joystick Switch: step 7, image 2 of 2
    • The joystick controller is soldered directly to the circuit board. You can find instructions for removing soldered components here.
    • The joystick controller is secured by 12 solder connections. Once these have been desoldered, the controller can be removed.
    Ask FixBot
3 other people completed this guide.
Clement Cheung
643 Reputation
5 Guides authored
Cal Poly, Team S18-G5, White Winter 2019 Member of Cal Poly, Team S18-G5, White Winter 2019
CPSU-WHITE-W19S18G5
2 Members
14 Guides authored
3 Guide Comments
You can solder replacement Xbox One analog sticks right? I have some stick drift and can’t test this until my university reopens, but when it does I want to try fixing it.
Edit: I have the Dell controllers but they seem identical to the HP ones in this guide.
Vincent - Reply Share
I think this might be the stick: https://www.mouser.com/ProductDetail/Alp...
Alps RKJXV 23 degree 10K ohm multi-directional switches
I haven’t soldered it yet so do not take my word as fact, it just looks right.
I have one issue post doing this. I reaoldered everything. The multimeter doesn't read OL anywhere BUT the controller will not power on when reassembled.
Layrinn - Reply Share
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 30
All Time: 1,754
